Rear Wheels Locked After Rotor Replacement
Thanks inadvance,
Mike
Thanks in advance,
Mike
Acutally you don't even need to do that. If you can get the rotors on, just drive the car around and the brake shoe will wear down on its own and then self-adjust back to the correct spot.
The proper method of adjustment is as follows, with the car properly supported on jackstands and tranny out of gear:
1) Release parking brake lever all the way down.
2) Remove wheel, caliper, caliper bracket and rotor.
3) the star adjustment wheel is located between the ends of the parking brake shoe. Make sure it is free moving - if not remove, clean and lube with some high temp silicone lube.
4) Center the parking brake shoe and try to install rotor. If rotor will not go on easily, adjust star wheel to allow shoe to slightly relax reducing diameter.
5) Reinstall rotor and check for ease of rotation. The shoe should barely make contact with the inside rotor brake surface. If not remove rotor and adjust star wheel for proper shoe contact. You will hear it rub slightly when rotating rotor if properly adkusted.
6) Once proper contact is reached, activate parking brake lever, it should pull up 1/2 - 2/3 of the way up and stop, firmly applying brake. If it goes too far, the shoe is not properly centered and needs to be readjusted.
7) Reinstall caliper bracket, caliper, wheel and repeat entire process on the other side.
Now you will have a properly working emergency brake.
Peter
I was able to get the rotors and wheels and everything back on but the brakes are still locked up on both sides. The car will drive, I just didn't want to do damage to anything. So your saying it should re-adjust? How long should that take?
The "re-adjustment" happens as the pads wear down. It's not adjusting at all.
Peter
DO NOT DRIVE THE CAR THIS WAY !!! constant pressure of the shoe on the drum will cause overheating of the shoe material. It will not "wear into proper adjustment", the shoe will overheat and crystalize the friction material causing it to disintegrate. When that happens, you have a real mess that takes 3 times as long to fix and a LOT MORE MONEY !!!
Peter
Not to mention the negative impact all that heat could have on the other wheel components...
