4th gear synchro
Old Sep 29, 2011 | 10:59 AM
6spdchevy's Avatar
6spdchevy
Default 4th gear synchro
I'm sure this thread has come up over and over, but i cant find exactly what im looking for. I grind from 3rd to 4th in my 98 6 spd. I imagine ive worn out the synchro but im no expert when it comes to this. anything else i should look into? And what should i expect to spend to have it repaired?
Old Sep 29, 2011 | 01:42 PM
cdkcorvette7's Avatar
cdkcorvette7
Yeah... 4th gear synchro going is pretty common.
The cost depends on how much of your own work you can do. Dropping the drivetrain will usually cost 5 - 7 hours of labor, so... $500 - $800. Disassembling the transmission and putting it back together with new components will usually cost between $400 - $700 for the labor plus the cost of parts.
I would very highly recommend either RKT56 or RPM Transmissions...
Old Sep 29, 2011 | 02:23 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Too bad your not local to Dallas. My tuner rebuilds 6 speeds in his shop with ALL RPM good stuff. He did mine for around $1600 removed/rebuild/installed. Feels AMAZING NOW !!!
Mine was also suffering the 3-4 grinding issue on occasion.
I would recommend RPM rebuild it for you.
Toque
Old Sep 30, 2011 | 12:46 AM
TriplBlk's Avatar
TriplBlk
RKT-56.com FTW
Old Sep 30, 2011 | 01:09 PM
chevy406's Avatar
chevy406
My '99 MN6 is currently grinding 4th - well only if I forget and try to use 4th. I have priced out the parts to rebuild a C5 T56, and just the parts to rebuild plus upgrade to "Level 2" are close to $900. I picked up a M12 rebuildable core so I can build it at my own pace, and then swap out my MN6 with minimal downtime.
Old Sep 30, 2011 | 10:51 PM
NearlyGone85's Avatar
NearlyGone85
I am also grinding into 4th if i am not careful. What I have found is that if i press the clutch coming out of 3rd, let it out and then press it again while going into 4th, it never grinds. I am going to try and flush/bleed the system. heard that helps...dont know if maybe that might help for a temporary fix. one can dream i guess
Old Sep 30, 2011 | 11:16 PM
TriplBlk's Avatar
TriplBlk
Idk where you got your prices try out gearbox.org
Old Oct 1, 2011 | 12:12 AM
cdkcorvette7
You can drive a stick shift with every single synchro shot and never grind if you learn how to match revs...
Old Oct 1, 2011 | 11:50 AM
chevy406's Avatar
chevy406
I did a price comparison with 3 suppliers (including TheGearBox). What I am buying is a basic rebuild kit (including carbon rings, seals, lock rings) plus upgraded bronze fork pads, solid keys for 3-4 synchro, steel 3-4 shift fork, and a complete 5-6 synchro assembly. A basic rebuild will cost ~$500 in parts. With these upgrades and me having to replace the 5-6 synchro assembly ($115) it will run me a little over $800.
Old Oct 1, 2011 | 12:59 PM
TriplBlk's Avatar
TriplBlk
Apparently you have to reshim everything too.
Old Oct 4, 2011 | 12:33 PM
6spdchevy's Avatar
6spdchevy
Thanks guys! I'll get ahold of RPM. I've heard a lot of good things about them. Are they out of Indiana?
Old Oct 5, 2011 | 02:37 AM
Qweklain's Avatar
Qweklain
Yep, my fourth grinds when it is cold if I drive how I normally do. To prevent the grind I just hold the clutch in a tid' bit longer until the revs come down to perfectly match. I have not had it grind once yet doing this.
To 4th gear synchro
