LS2 intake bolts
Old Sep 29, 2011 | 07:22 PM
riggs 74's Avatar
riggs 74
Default LS2 intake bolts
I bought some intake bolts from summit that were marked as LS1 intake bolts, but was told that they are for the LS2 manifold as well is this true? I tried to install them and they feel like they will bottom out before I can achieve the proper torque. Has any one else had to deal with this problem?
Thanks for any help you can be.
Riggs.
Old Sep 30, 2011 | 02:51 PM
JohnJ@Texas-Speed's Avatar
JohnJ@Texas-Speed
Premium Supporting Vendor
Those intake bolts should work just fine for you. The only intake bolts that are different are trucks, and LS7 intakes.
Old Sep 30, 2011 | 05:39 PM
riggs 74's Avatar
riggs 74
Thank you for the reply. I just wasn't sure with the way they seam to bottom out the threads, if that is what really is taking place. I just wanted to make sure before I attempt to tighten them down.
Thanks again.
Riggs
To LS2 intake bolts
