Oil Pump swap question
Old Oct 3, 2011 | 09:19 PM
69SSC5's Avatar
69SSC5
Default Oil Pump swap question
put a new oil pump on start the engine... should the oil pressure come up immediately or does the pump take 2, 5, 10 seconds or so to prime?
Old Oct 3, 2011 | 10:13 PM
Paul 75 L82's Avatar
Paul 75 L82
You should be able to unplug the coils and crank the motor till you see some oil pressure. Then you can replug the coils and start the motor.
Old Oct 3, 2011 | 10:25 PM
a/c man's Avatar
a/c man
all motors take 2 sec or so after starting to see pressure its mechanical not electric
To Oil Pump swap question
