no start
Old Oct 3, 2011 | 11:10 PM
MGirouard's Avatar
MGirouard
3rd Gear
Default no start
have a 2000 frc manual trans with a no start codes pulled are
40 BCM B2583H
99 HVAC B0367H
B0441H
no start doesn't happen all the time and when it does you get no noise from starter, any suggestions
Old Oct 3, 2011 | 11:20 PM
Jnape's Avatar
Jnape
With no real codes, I say the starter solenoid is worn out. You can whack it with a stick when it is acting up and see if it starts up.
Old Oct 3, 2011 | 11:28 PM
cdkcorvette7's Avatar
cdkcorvette7
The starter sits really close to the headers and the heat kills the starter solenoid. Take a long screwdriver and use it to tap on the starter to see if that fixes it. If it works after that your starter solenoid needs to be replaced. The solenoid itself is a little hard to find sometimes so you may have to replace the whole starter. If you do; I'd highly recommend wrapping the new starter in heat wrap.
Old Oct 4, 2011 | 11:03 AM
dougbfresh's Avatar
dougbfresh
Does it crank?
To no start
