What is the column lock bypass?
Old May 3, 2002 | 10:39 AM
dwaynelombardi's Avatar
dwaynelombardi
Default What is the column lock bypass?
I keep reading this in peoples sig under their mods, what does the column lock bypass mean?
Old May 3, 2002 | 10:59 AM
JC in XTC5's Avatar
JC in XTC5
Default Re: What is the column lock bypass? (dwaynelombardi)
The CLB is a small electronic device that bypasses GM's column lock mechanism (CLM). The CLM is known to fail, which results in the car being disabled since the BCM will not allow you to drive the car with a locked steering column.
The CLB plugs into the existing wiring harness and simulates the "signals" that the BCM monitors to make it happy while disabling the column lock, which is useless anyway. The CLM was removed from all Automatic Xmission cars in 2001, and was supposedly modified for 6-spds. It was still required in 6-spds to pass some federal requirement for safety, while the Autos pass that requirement with it's shift interlock.
Old May 3, 2002 | 06:44 PM
B. Stewart's Avatar
B. Stewart
Even if you haven't had a problem with your column locking I would install the CLB! It will give you 100% peace of mind. I think that L.A.P.D. still has some. Give Shawn a call! :yesnod:
Old May 3, 2002 | 06:56 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Default Re: What is the column lock bypass? (B. Stewart)
are 2000 coupes with auto affected by this problem ??????
Old May 3, 2002 | 07:24 PM
ghost.rider's Avatar
ghost.rider
Default Re: What is the column lock bypass? (johnnyvettes)
All 2000's could be affected by the problem.
There was a TSB issued that affected 2000's with a vin beginning Y5116234 thru the End of Production
I suspect recall 01044 applied to the earlier ones in the 2000 model run.
You can see details of the TSB at http://forums.corvetteforum.com/zerothread?id=206322
Old May 3, 2002 | 07:50 PM
B. Stewart's Avatar
B. Stewart
Yes! I had to have mine flatbedded 3 times before I installed the CLB! :mad The dealer "fixed" it each time and the 2nd time was with the new and improved version!
Old May 3, 2002 | 08:39 PM
buzzme's Avatar
buzzme
When you say, "The dealer "fixed" it each time and the 2nd time was with the new and improved version!" are you talking about the factory recall ( http://forums.corvetteforum.com/zerothread?id=206322 )?
I have my Y2K scheduled to have the recall done next week.
Does the recall work?
Do I need to install the CLB in addition to the recall?
Old May 3, 2002 | 10:00 PM
ghost.rider
Default Re: What is the column lock bypass? (buzzme)
Buzzme
There was both a recall and a TSB.
If you have an A4, the FiX basically disconnects the column lock much like the bypass. On MN6's they apparently put in new parts which can fail again.
I have read stories that the bypass will not work on fixed (recalled/TSBed_)C5's but personally doubt that to be the case.
To What is the column lock bypass?
