Need help with codes
Old Oct 6, 2011 | 12:00 PM
rwlc5's Avatar
rwlc5
Default Need help with codes
My buddy got the following on his 2003 Z-06
The message center gave 3 messages:
Traction control system needs service
ABS system needs service
Stability control system needs service
He pulled the codes and got:
Left door control module B2282 B2284 U1064
Right Door control module B2283 B2285 U1064
Traction control C1214
Is all of this somehting in a module that can be repaired, or is it a module that needs to be replaced?
Thanks in advance for any insight
Old Oct 6, 2011 | 12:18 PM
cdkcorvette7's Avatar
cdkcorvette7
The 1214 is causing the messages in the DIC. Very common problem... Lots of info if you search.
http://www.absfixer.com/catalog/prod...f74pu3pg13kfp4
http://www.absfixer.com/how_do_i_rem...DelphiCorvette
or, if you can solder circuit boards:
http://forums.corvetteforum.com/c5-t...r-fleabay.html
