Urgent help required. C5 tech gurus please assist.
Old Oct 6, 2011 | 08:03 PM
wallyman424's Avatar
wallyman424
Default Urgent help required. C5 tech gurus please assist.
Recap: I'm a road racer, just finished swapping my new longblock in. Connected everything as it was before, all grounds as well.
So I've plugged everything in, and I gave it a crank.
It cranks freely, but does not fire. There is fuel in the rail. Its spitting out codes P1275 and P1276. I have no idea where to go from here.
Please help. I'm supposed to haul to VIR tomorrow afternoon.
Old Oct 6, 2011 | 08:12 PM
Corvette Don's Avatar
Corvette Don
Did you verify if there was definite spark?
Old Oct 6, 2011 | 08:30 PM
dougbfresh's Avatar
dougbfresh
Did you even search on those codes? What's the fuel pressure? Are you getting crank pulses??
Old Oct 6, 2011 | 08:55 PM
Greg_E's Avatar
Greg_E
Certainly not one of the experts, but maybe this will help.
The throttle body position sensor gives feedback to the TAC module when the accelerator is pressed. Does that move? Maybe you pinched a wire doing the swap. Just a thought.
The p1275 code is similar to this, but an undervoltage condition.
DTC P1276
Circuit Description
The accelerator pedal position (APP) sensor is mounted on the accelerator pedal assembly. The sensor is actually 3 individual APP sensors within 1 housing. Three separate signal, low reference and 5-volt reference circuits connect the APP sensor assembly to the throttle actuator control (TAC) module. Each sensor has a unique functionality. The APP sensor 1 signal is pulled up to the reference voltage as the accelerator pedal is depressed, from below 1 volt at 0 percent pedal travel, with the pedal at rest. To above 2 volts at 100 percent pedal travel, with the pedal fully depressed. The APP sensor 2 signal is pulled down to the low reference from above 4 volts at 0 percent pedal travel to below 2.9 volts at 100 percent pedal travel. The APP sensor 3 signal is pulled down to low reference from above 3.8 volts at 0 percent pedal travel to below 3.1 volts at 100 percent pedal travel. TP sensor 1 and APP sensor 1 share a 5 volt reference circuit that is connected within the TAC module. TP sensor 2 and APP sensor 2 share a 5-volt reference circuit that is connected within the TAC module. If only 1 APP sensor DTC is set, the redundant APP systems allow the TAC system to continue operating normally. One APP sensor DTC will not cause the Reduced Engine Power message to be displayed. Two APP sensor DTCs for the same sensor also will not cause the Reduced Engine Power message to be displayed. If an out of range condition is detected with the APP sensors, this DTC will be set.
Conditions for Running the DTC
DTCs P0606, P1517, or P1518 are not set.
The ignition switch is in the crank or run position.
The ignition voltage is greater than 5.23 volts.
Conditions for Setting the DTC
APP sensor 1 disagrees with APP sensor 2 by more than 10.5 percent and APP sensor 1 disagrees with APP sensor 3 by more than 13 percent.
All of the above conditions are present for less than 1 second.
Action Taken When the DTC Sets
The control module stores the DTC information into memory when the diagnostic runs and fails.
The malfunction indicator lamp (MIL) will not illuminate.
The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Failure Records.
If one or more APP sensor DTCs are set for a single APP sensor, the following occurs:
The control module will not command Reduced Engine Power mode.
The control module will use the remaining two APP sensors to calculate throttle response.
If certain multiple APP sensor DTCs are set for more than one APP sensor, the following occurs:
The control module commands Reduced Engine Power mode.
The APP indicated angle is limited to a predetermined value to limit the amount of throttle control.
The message center displays Reduced Engine Power.
If all three APP sensors are out of range, the following occurs:
The APP indicated angle is limited to 0 percent. The control module only allows the engine to idle.
Conditions for Clearing the DTC
A current DTC Last Test Failed clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
Clear the DTC with a scan tool.
Diagnostic Aids
Inspect the TAC module connectors for signs of water intrusion. When water intrusion occurs, multiple DTCs could be set with no DTC circuit or component conditions found during diagnostic testing.
When the TAC module detects throttle movement with a DTC P1275 set, a DTC P1276 also sets.
When the TAC module detects a condition within the TAC system, more than 1 TAC system related DTC may set. This is due to the many redundant tests that run continuously on this system. Locating and repairing 1 individual condition may correct more than 1 DTC. Disconnecting components during testing may set additional DTCs. Keep this in mind when reviewing the stored information, Capture info.
For an intermittent, refer to Intermittent Conditions .
Test description
The numbers below refer to the steps numbers in the diagnostic table.
This step determines if a communication condition exists.
This step isolates an internal APP sensor failure. The condition may only occur at a certain accelerator pedal position. Monitoring the APP angles for sensor 2 and sensor 3 is an accurate way of verifying the actual position of the pedal. The APP angles for all 3 sensors should be within a few percentages of each other. When the pedal is at rest, the APP angle for all 3 sensors should be 0 percent. When the pedal is fully depressed, all APP angles should be 100 percent.
The APP sensor 1 shares a common 5-volt reference circuit with the TP sensor 1. Monitoring the TP sensor 1 voltage aids in diagnosing the APP sensor 5-volt reference and the low reference circuits. If the scan tool displays near 0 volts then the circuits are OK.
With the TAC module still connected, this test will help determine a short to the signal circuit either within the TAC module or the wiring.
This step determines whether the TAC module or a shorted circuit is causing the condition.
When the TAC module detects a condition within the TAC system, more than 1 TAC system related DTC may set. This is due to the many redundant tests that run continuously on this system. Locating and repairing 1 individual condition may correct more than 1 DTC. Disconnecting the components during testing may set additional DTCs. Keep this in mind when reviewing the stored information, Capture info.
DTC P1276 APP Sensor 1 Performance Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Is DTC P1518 also set?
Go to DTC P1518
Go to Step 3
3
Important
Do not depress the accelerator pedal.
Turn OFF the ignition for 15 seconds.
Start the engine.
With a scan tool, observe the diagnostic trouble code (DTC) information.
Did any other TAC Module or APP sensor DTC set except P1125?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 4
4
With a scan tool, observe the APP sensor Agree/Disagree parameters.
Does the scan tool indicate Disagree for any of the APP Agree/Disagree parameters?
Go to Step 6
Go to Step 5
5
Turn OFF the ignition.
Turn ON the ignition with the engine OFF.
With a scan tool. observe the APP sensor angles for all 3 APP sensors.
Slowly depress the accelerator pedal, stopping at 25, 50, 75, and 100 percent.
Slowly release the accelerator pedal, stopping at 75, 50, 25, and 0 percent.
Does the scan tool indicate APP sensor 1 angle within 10.5 percent of the APP sensor 2 angle and APP sensor 1 angle within 13 percent of the APP sensor 3 angle during the above test?
Go to Diagnostic Aids
Go to Step 6
6
Disconnect the APP sensor harness connector.
Connect a fused jumper between the APP sensor 1 5-volt reference circuit and ground.
With a scan tool, observe the TP sensor 1 voltage parameter.
Does the scan tool indicate TP sensor 1 voltage at the specified value?
0.0 V
Go to Step 7
Go to Step 11
7
Connect a fused jumper between the APP sensor 1 5-volt reference circuit and the APP sensor 1 low reference circuit.
Does the scan tool indicate TP sensor 1 voltage at specified value?
0.0 V
Go to Step 8
Go to Step 12
8
Connect a fused jumper between the APP sensor 1 signal circuit and the APP sensor 1 5-volt reference circuit.
With a scan tool, observe the APP sensor 1 voltage parameter.
Does the scan tool indicate APP sensor 1 voltage near the specified value?
5.0 V
Go to Step 14
Go to Step 9
9
With a DMM, test for a short between the APP sensor 1 signal circuit and all other APP circuits at the APP sensor harness connector.
Does the DMM indicate a short to another circuit?
Go to Step 10
Go to Step 13
10
Disconnect both of the TAC module harness connectors.
With a DMM, test for a short between the APP sensor 1 signal circuit and all other APP circuits at the APP sensor harness connector. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 18
Go to Step 15
11
Disconnect the TAC module harness connector containing the APP circuits.
With a DMM, test the APP sensor 1 5-volt reference circuit for an open or the high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 18
Go to Step 15
12
With a DMM, test the APP sensor 1 low reference circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 18
Go to Step 15
13
With a DMM, test the APP sensor 1 signal circuit for an open or the high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find an open or high resistance?
Go to Step 18
Go to Step 15
14
Inspect for poor connections at the harness connector of the APP sensor. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 18
Go to Step 16
15
Inspect for poor connections at the harness connectors of the TAC Module. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 18
Go to Step 17
16
Replace the APP sensor assembly. Refer to Accelerator Pedal Position (APP) Sensor Replacement .
Did you complete the replacement?
Go to Step 18
17
Replace the TAC module. Refer to Throttle Actuator Control (TAC) Module Replacement .
Go to Step 18
18
Use the scan tool in order to clear the DTCs.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 19
Go to Step 2
19
With a scan tool, observe the stored information, Capture info.
Does the scan tool display any DTCs that you have not diagnosed?
System OK
Old Oct 6, 2011 | 09:37 PM
wallyman424
Fixed it guys. Thanks.
Was a ground issue.
To Urgent help required. C5 tech gurus please assist.
