Dumb head question.
Old Oct 7, 2011 | 03:56 PM
walleyejack's Avatar
walleyejack
Default Dumb head question.
I am sure I know the answer, but would like to confirm. 2005 243 heads on a 2002 block,as the bore is different, will this work ? I think not. but......what do I know.
thanks
Old Oct 7, 2011 | 05:18 PM
baxsom's Avatar
baxsom
shouldnt 2005 heads be 799 ones.
either way, 243 and 799 heads will fit
Old Oct 7, 2011 | 05:40 PM
tlove32's Avatar
tlove32
2005's have 243's - they're the same castings that are on C5Z's....and they'll fit perfectly
Old Oct 7, 2011 | 05:52 PM
walleyejack
well the bore is slightly different, 3.89 to 4.00, won t matter ? and I know they will match up with intake, just the bore I am nervous about.
Old Oct 7, 2011 | 06:28 PM
1999_TRC's Avatar
1999_TRC
What are you concerned about? It's the same casting, the only difference between the LS6 and LS2 head are the valves(type).
Old Oct 7, 2011 | 06:41 PM
JTrotter's Avatar
JTrotter
The bore doesn't matter (in this example). The head chambers do not fully cover the cylinder bore, not even on stock LS1 heads.
The only time bore becomes a true factor in fitment compatibility, is when valve diameters are too big and would contact the cylinder wall at peak lift. This is why an LS3/L92 head will not fit a 346 (for example).
The 243/799 are the same head, just cast in different plants. You might find a stock LS2 with 243s, you might find one with 799s. You may even find a car with one of each, bone stock.
And whether that 243 casting came off a 2001 or a 2006 is irrelevant, it's still the same identical part.
Old Oct 7, 2011 | 07:44 PM
walleyejack
thank you for the specific explanation.
To Dumb head question.
