Reversed Window Action
Old Oct 8, 2011 | 11:02 AM
Devil@theCrossroads's Avatar
Devil@theCrossroads
6th Gear
Default Reversed Window Action
My driver side window decided once it was down it did not want to work anymore. I found that inside the window motor was full of carbon dust. I cleaned it all out and put everything back together. All appeared to work well. I used the car for the first time since the repair and found that thge driver side window switch now works in reverse. Up is down and down is up. I haven't taken it apart yet because I don't think it is hurting anything. If all wiring only fits in one direction(I believe).........what could have gone wrong?
Old Oct 8, 2011 | 11:44 AM
87SAM's Avatar
87SAM
See post #5.
http://forums.corvetteforum.com/c5-t...uild-pics.html
Old Oct 8, 2011 | 12:34 PM
Devil@theCrossroads
6th Gear
Thank you. I try reversing the motor housing.
To Reversed Window Action
