Dyno run questions...
Old May 3, 2002 | 04:38 PM
BBC5's Avatar
BBC5
Default Dyno run questions...
Could I have gotten better numbers if I hadn't disconnected the battery before this Dyno run? If so, which way?
Also, the A/F was way too rich. Would these numbers have been different if I didn't disconnected the battery? If so, which way?
Thanks...
[Modified by BBC5, 3:39 PM 5/3/2002]
Old May 4, 2002 | 12:17 PM
BBC5's Avatar
BBC5
Default Re: Dyno run questions... (BBC5)
Can anyone help?
BBC5
Old May 4, 2002 | 05:55 PM
levrac68's Avatar
levrac68
Don't know for sure. TTT for some help. :cheers:
Old May 5, 2002 | 11:19 PM
BBC5's Avatar
BBC5
Default Re: Dyno run questions... (levrac68)
I really hate to spend another $100 to find out...
Any help?
BBC5
Old May 6, 2002 | 06:03 PM
levrac68's Avatar
levrac68
30 + thousand members and not one good ianswer. :rolleyes:
Old May 6, 2002 | 08:29 PM
Flintstone's Avatar
Flintstone
Well, since you're running a blower, that reduces the # of members that have similar setups to something a little less than 30,000.
For N/A cars, as a general rule you a) don't want to fill up with > 5 gallons of fuel before a dyno run, as the fuel trims get reset by the PCM (in the event you got inferior fuel, yadda yadda), and b)drive the **** out of it on the way to the dyno because the PCM compensates for the driving style.
So, you probably lost some by disconnecting before the run. I would guess you the rich problem is related as well. BUT, I don't have a blower so it is very possible I don't have a clue WTH I'm talking about.
F
To Dyno run questions...
