Need Alignment specs for '02 Z06 ASAP
Old May 3, 2002 | 04:44 PM
C5Longhorn's Avatar
C5Longhorn
Default Need Alignment specs for '02 Z06 ASAP
Hi,
I've lowered my car and will be taking it in to get aligned tomorrow morning and I need the alignment specs for an '02 Z06.
Is there a difference between the '01 and '02 Z06 specs?
Thanks,
Old May 3, 2002 | 05:00 PM
The One's Avatar
The One
Default Re: Need Alignment specs for '02 Z06 ASAP (rschiltz)
From Al Hanna's site: http://temp.corvetteforum.net/c5/too..._alignment.htm
JC
Old May 3, 2002 | 05:02 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Need Alignment specs for '02 Z06 ASAP (The One)
Thanks for the fast response.
Old May 3, 2002 | 05:05 PM
C5Longhorn's Avatar
C5Longhorn
Do they come from the factory with moderate or aggressive settings?
Thanks,
Rick
Old May 3, 2002 | 05:08 PM
abraham's Avatar
abraham
Let me take a wild guess... moderate. :p:
Old May 3, 2002 | 05:10 PM
The One's Avatar
The One
No problem. I take from this forum, so I try to give back every now and then. ;)
JC
Old May 3, 2002 | 05:13 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Need Alignment specs for '02 Z06 ASAP (abraham)
Yeah, I guess my question was more, what is the difference between the Service preferred and the Moderate and Aggressive settings? Are those additional optional settings?
Old May 3, 2002 | 07:33 PM
alanh's Avatar
alanh
Service Preferred will give you the best tire wear of the three settings. Moderate is close to the factory settings on GM document #776629, but a lot of people have complained about inside tire wear. Stay away from the Aggressive settings unless you're spending a lot of time on the auto-x track.
Old May 4, 2002 | 01:10 AM
TooManyIDs's Avatar
TooManyIDs
Updated my spreadsheet late tonight (Friday, 5/3). Originally had rear camber specs for a Coupe, now updated to Z06 specs from the 2002 service manual.
Moderate & Aggressive columns are from what I compiled from various forum posts. Use at your own risk.
I run the moderate settings and may update them from time to time.
Old May 4, 2002 | 03:04 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Need Alignment specs for '02 Z06 ASAP (TooManyIDs)
Thanks Al. I just printed it out again.
To Need Alignment specs for '02 Z06 ASAP
