Help, help, Clutch squeaking after C/M line mod!!!
Old May 4, 2002 | 01:59 AM
2001C5's Avatar
2001C5
Cruise-In II Veteran
Default Help, help, Clutch squeaking after C/M line mod!!!
Hey, I installed the line tonight. When I first started pushing in the pedal it stuck to the floor. Once it came backup it is now making a horrible squeaking nosie when I press in the pedal. Any ideas? I have not started the car yet, it's too late at night.
Old May 4, 2002 | 02:23 AM
2001C5's Avatar
2001C5
Default Re: Help, help, Clutch squeaking after C/M line mod!!! (2001C5)
A little more info... noise is not coming from the pedal. It sounds like it is coming from the clutch itself. Squeaks both on the way in and out.
Old May 4, 2002 | 10:21 AM
chuckster's Avatar
chuckster
Do a full bleed and replace ALL the fluid. You should be fine...The slightest air in the line will give you fits.
To Help, help, Clutch squeaking after C/M line mod!!!
