Help with Hurst Shifter Installation
Old May 4, 2002 | 11:24 AM
pross's Avatar
pross
6th Gear
Default Help with Hurst Shifter Installation
I have just installed a hurst shifter in my 2000 FRC MN6 and can't get it into reverse. Everything else works fine. Does anyone know how to fix this problem. I have a feeling it has to do with the shift rod, but I'm not sure. I don't want to have to reinstall the stock unit for the weekend, but Hurst tech services is closed until Monday, so any help will be appreciated.
Peter Ross
Old May 4, 2002 | 12:09 PM
CRUZMISL's Avatar
CRUZMISL
Default Re: Help with Hurst Shifter Installation (pross)
hmm strange, try putting it in 1st before going to reverse. Total guess though. Also the side to side is much firmer than stock so use some force.
Joe
Old May 4, 2002 | 12:48 PM
cart3113's Avatar
cart3113
Check this thread out. You may have the same problem. Hope this helps.
http://forums.corvetteforum.com/zerothread?id=270193
Old May 4, 2002 | 02:08 PM
mac1009's Avatar
mac1009
Do you have the adjustable stops set? They're not required w/ the B-W T56, that trans already has them built in. The stop may be what's preventing it. Try removing them and see if it fixes your problem. I know that one of the nuts popped off of Patches shifter and he wasn't able to shift. Just an idea.
Dave
Old May 4, 2002 | 03:56 PM
shockwave's Avatar
shockwave
Peter Ross
I assume your problem occurs with the engine running...I say this because with the engine off, my MN6 reverse shift is disabled.
Old May 4, 2002 | 04:20 PM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
Stops removed from my Hurst on day 1 :D
Old May 4, 2002 | 04:26 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Help with Hurst Shifter Installation (Fast Lane)
I bet thats not the problem in this case. :D
Old May 4, 2002 | 10:22 PM
luvinc5's Avatar
luvinc5
Default Re: Help with Hurst Shifter Installation (racer44)
I thought I lost reverse when I first put in the Hurst shifter and "dry" shifted. It's there. Start up the vette and you'll get the reverse gear.
Old May 6, 2002 | 07:08 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Re: Help with Hurst Shifter Installation (luvinc5)
Luvinc5 and Shockwave are 100% correct........it happened with my installation too.....
To Help with Hurst Shifter Installation
