Harmonic Balancer
Old Oct 17, 2011 | 10:59 AM
MikeGB's Avatar
MikeGB
Default Harmonic Balancer
Hey Guys,
New Vette Owner here. I bought a Navy Metallic 2001 LS2 with 71K miles on it about a month ago and love it. When I first bought it, I noticed some movement of the crankshaft/harmonic balancer. Maybe 1/32 to 1/16 of an inch. (had one replaced on a Nissan Pathfinder once. Dealer made it seem like it was a huge deal and I had it towed in for repair) My local Corvette guy (Leo's Corvette's Pensacola Florida) said some movement was normal in a Vette. Have any of you had trouble with this?
Old Oct 17, 2011 | 11:09 AM
dougbfresh's Avatar
dougbfresh
Many threads on this-do an Advanced Search.
Old Oct 17, 2011 | 01:36 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by MikeGB
Hey Guys,
A little movement is normal; can't tell without looking at it of yours is wobbling too much or not...
Replacing it is a pretty big job. The steering rack has to come out...
Old Oct 17, 2011 | 08:26 PM
Paul 75 L82's Avatar
Paul 75 L82
If your going to change the balancer you might as well install a new cam. It's not much more work.
Old Oct 18, 2011 | 05:27 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Hey Guys,
LS2, What happened to the original motor? You should probably ask the previous owner/installer if the harmonic balancer had been previously replaced and if so, did they follow the OEM's procedure.
Have you noticed any engine vibration at elevated RPM, is it moving axially or radially? That amount seems excessive.
The outer ring is bonded to the inner hub assembly with a hard rubber or plastic type material. Over time it degrades and the outer ring will start to separate from the inner hub. When this happens the outer ring will either walk forward and rub against the streering rack or move backwards and rub against the timing chain cover. In either case it's easy to see. By this point you may notice excessive belt noise and the belt may even come off the pulley.
If yours is really moving that much you should be able to see some degradation of the bonding material. You will need a flashlight and inspection mirror to perform the inspection.
Old Oct 18, 2011 | 06:42 AM
lucky131969's Avatar
lucky131969
..perhaps, but at the end of the day, it will add ~ $1000 to the project, once you change the cam, timing set, oil pump, and tune.
Old Oct 18, 2011 | 08:02 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
bull $hit
Old Oct 18, 2011 | 08:40 AM
MikeGB's Avatar
MikeGB
Thanks. That is how I first found it. The second time I drove it, I heard belt noise. I popped the hood and saw the pulley on the crankshaft moving in and out (front to back) I called the dealer I bought it from who said he had the car inspected in South Carolina which is where it came from. I took it back to him and he took it to a Corvette mechanic here in Florida who changed the belts and tensioner. He said it was a good car and that the amount of movement was normal. I just wanted to check with the experts and see if you all also have some movement of that pulley.
Old Oct 18, 2011 | 08:57 AM
lucky131969
If you are suggesting that the balancer is translating about the axis of rotation (i.e. toward the engine, and toward the rack).....that is NEVER acceptable. It suggests the bolt has come loose, or the balancer is separating.
To Harmonic Balancer
