Sqeaking suspension.....for dummies?
Old Oct 17, 2011 | 12:32 PM
lwd2000's Avatar
lwd2000
Default Sqeaking suspension.....for dummies?
I too have the squeaking suspension issue. My 01 squeaks everytime I go over any little bump at all. I am relieve that it is a simple diy fix to hopefully get it fixed. Does anyone have pictures of the process of lubricating the sway bars? I'm a bit on the auto mechanic challenged side and want to be sure I'm taking off /lubricating the right stuff. Any pics either photos or drawn would be much appreciated!
Old Oct 17, 2011 | 01:58 PM
lwd2000's Avatar
lwd2000
Cancel this request........found what I needed from a post in 2009 Thanks.
Old Oct 17, 2011 | 08:28 PM
shaft's Avatar
shaft
Navigator
Default lube
please send me the link
thanks
Old Oct 17, 2011 | 08:56 PM
lwd2000's Avatar
lwd2000
thanks
This is the link I found and plan to use.
http://www.ls1howto.com/index.php?article=16
Old Oct 17, 2011 | 09:22 PM
bighank's Avatar
bighank
Default I swapped FE1 bars for FE3 and used teflon tape
I didn't try using grease on the bushings but used about 3 or 4 layers of plumbers teflon tape on the bar under the bushings instead. So far so good. Might want to try that.
Old Oct 18, 2011 | 01:56 PM
Piper250's Avatar
Piper250
This link demonstrates how to replace your sway-bars and this may or may not solve your squeeking suspension issue.
Case in point, I just did the front and rear sway bars, new sway-bar bushings, marine grease, new sway-bar-end-links and 4 new shocks.
Guess what - I still have the suspension squeeks and groans.
So now we are doing a replace of the front tie-rod-ends, front lower ball-joints and front control arm busings.
To Sqeaking suspension.....for dummies?
