Dry NOS System.
May 4, 2002 | 04:33 PM
St. Jude Donor '05
Dry NOS System.
My brother inlaw was talking about a dry nos system for the ls1 camaro any idea's on this. I guess it injects nos into the air intake through the maf.
May 4, 2002 | 05:13 PM
Re: Dry NOS System. (golfman)
Everyone has their preferences. I prefer a wet system. I feel I have more control over the mix.
May 4, 2002 | 06:13 PM
The way I interpret the 2 systems is this
Dry::: In before MAF and then the MAF tells the computer to dump in more fuel.
Wet::: Takes fuel from fuel rails and injectors making the pump send more fuel to compensate.
Either kit I would want an extra or bigger volume fuel pump.
This is just what I interpret if true or not IDK.
May 4, 2002 | 07:50 PM
St. Jude Donor '05
Re: Dry NOS System. (Ben01C5)
Isn't easier to install a dry system. If you were doing it yourself. Do they both make the same kind of horsepower.
May 4, 2002 | 09:18 PM
I have a dry 100 shot system, and it works great. The wet is a little harder to install, but if you wanna jet above a 100 shot, i would go wet.
Daren
May 4, 2002 | 10:39 PM
Re: Dry NOS System.
WETTER IS BETTER!!! :D
:cheers:
-Tuan
May 5, 2002 | 05:43 PM
From: 26 NM out the 304 radial of the ORD VOR Illinois
Re: Dry NOS System. (Tuan Le)
DRY is like PIE in the SKY
May 5, 2002 | 08:14 PM
Re: Dry NOS System. (Supercharged)
i prefer the lubricated ones better. :smash: :crazy:
May 6, 2002 | 10:14 PM
St. Jude Donor '05
Re: Dry NOS System. (robsvette)
Isn't very easy to install. wet system look much harder than the dry.
May 6, 2002 | 10:25 PM
The install on the wet kit is not that much harder. All you have to do is tap the fuel rail and run a line to the second solenoid. That is it.
:cheers:
-Tuan
May 6, 2002 | 10:34 PM
St. Jude Donor '05
If i had it installed anyone know about how much normally for something like this :smash:
May 6, 2002 | 10:39 PM
For a complete install with all bells & whistles, it runs anywhere from $400 to $700.
May 7, 2002 | 12:02 AM
St. Jude Donor '05
Thanks for that info. :)
