Front lower shock mount bolts?
Old Oct 18, 2011 | 03:30 PM
djamigolxr50's Avatar
djamigolxr50
Default Front lower shock mount bolts?
Does anyone know where I could find the following:
Front lower 13mm shock mount bolts for C5 Corvette.
I tried searching online, but nobody seems to be selling it (including ebay).
Does anybody know where an identical or similar replacement bolt could be purchased (same strength and material)?
Any help will be appreciated.
Thank You
Old Oct 18, 2011 | 04:02 PM
hotwheels57's Avatar
hotwheels57
First, contact Gene or Patrick at GMPARTSHOUSE. You get real knowledgeable people who answer the phone. They should be able to provide you with oem GM bolts if they're still available (or available separately)...
http://www.gmpartshouse.com/
If that doesn't pan out, try McMASTER-CARR. You'll need to know the exact specs. They should have something very close to oem bolts...
http://www.mcmaster.com/#
Old Oct 18, 2011 | 04:36 PM
lucky131969's Avatar
lucky131969
Thank You
Those should be GM p/n 11516494
Old Oct 19, 2011 | 11:15 PM
lucky131969
Thanks a lot everyone
I just found this great alternative to Grade 8 factory bolts:
http://www.jegs.com/i/ARP/070/761-1006/10002/-1?CT=999
Alternative? The length is not the same as the factory bolt. Good luck.
Old Oct 20, 2011 | 09:23 AM
djamigolxr50
Yes, the ARP bolt is short.
I assume M8 x 1.25mm x 55mm would be the correct specs for it.
..and the correct new GM Part number is: 14066450
I'll search for it...
Old Oct 20, 2011 | 11:33 AM
dgoetz's Avatar
dgoetz
These guys have a ton of C5 parts and are getting more in all the time.
http://www.corvetterecycling.com/
Old Aug 29, 2014 | 12:01 PM
Razodo's Avatar
Razodo
Just went through this so I wanted to revive an old thread with the updated info. I Couldn't find the bolts online and the parts numbers above are either discontinued or wrong. I went to a chevy dealer and order them. The parts numbers are:
Bolt: 10095393
Nut: 11609746
Old Aug 29, 2014 | 12:03 PM
Razodo's Avatar
Razodo
New (Left); Old (Right)
Old Jan 29, 2015 | 04:41 AM
corvet786c's Avatar
corvet786c
Thanks Rosado
To Front lower shock mount bolts?
