C6 front spring on a C5.....
Old Oct 19, 2011 | 01:34 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default C6 front spring on a C5.....
I was on the Hyperco web site viewing their offerings and noticed that their part number for a front spring (Track Series) on a C5 or C6 was the same. Found that curious so I then searched this and a few other forums asking if a C6 front spring would fit a C5. Seems there is general consensus that the rears will not work. The results were not consistent about the fronts, so I am posting here to see if anyone has a definitive answer to the question.
Thanks.
Old Oct 20, 2011 | 11:10 AM
STRODDER's Avatar
STRODDER
Check part numbers for both at the dealer.
Old Oct 20, 2011 | 11:33 AM
chaase's Avatar
chaase
St. Jude Donor '12
I can see the rear not working. I thought the whole rear cradle was different. I know lots of racers have switched to using the C6 rear because it is stronger, but it requires you to use the C6 rear cradle.
Old Oct 20, 2011 | 12:32 PM
alxltd1's Avatar
alxltd1
That may not answer the question as the C6 and C5 spring rates will be different, which I expect, and would have different part numbers. But the springs may still actually be interchangeable as to physical size, mounting points, etc. So while lets say a C6 Z51 front spring may have a different part number, if it were interchangeable with a C5 you could use it and increase your front spring rate to 526LBS which is about the same as a C5 Z51/Z06 front spring of 525LBS.
The only reason I bring this up is that I have to replace a front spring on my 2000 Z51 and I found a C6 Z51 at a very good price. The seller is convinced that they are interchangeable and before buying it I was trying to be sure. I am sure the rears are not because as mentioned the entire rear cradle is different.
To C6 front spring on a C5.....
