You certainly don't need a 35W or 55W load. A load that is about 1W or 2W is all you need to keep the headlights retracting.
Peter
I can't accurately tell without pulling off my headlights. All I can see is the ballast and the backside of the bulbs. I don't have any fancy projectors or anything like that. The hi-beams look stock and the resistors in the fusebox are 10A.
I have to turn on the hi-beam switch to close the buckets. I think it's really tacky leaving it like this, and I spent hours last week chasing a weird electrical issue, while the whole time it was just the buckets wanting to come up for no reason.
I like the look of the light though...big improvement from stock. I ordered the 35W resistor from a vendor.
From: eustis FL Saved and blessed; what else matter?
Resistors are rated in ohms and watts. The ohm rating tells you how much load you are adding to the circuit, The watt rating tells you how much current the resistor can handle without burning out. You need HIGH watts to make the resistor last. You need enough ohms to mimic the incandescent light amp draw. If you go LOWER than 55 watts, your resistor will burn out quickly. The reason a marker lamp works is because the lamp dissipates a lot of heat easily. Even a 55 watt resistor will get VERY hot. A 5 watt resistor in parallel with a headlight circuit could get hot enough to start a fire if it lasted long enough. Go with what;s proven to work instead of risking your car by trying to reinvent the wheel.
Huh? A 5W resistor will dissipate 2W of power no problem. A resistor that provides a couple of watt of load is all you need. A 5W resistor providing a couple of watts of load is not the same as trying to provide 55W of load with a 5W resistor.
The 35W or 55W resistors are oversized and unnecessary. But, the vendors sell them so everyone thinks that's what's needed. To be honest, I look at those 55W prepackaged load resistors and find it extremely hard to believe that size of resistor can provide 55W of load. They look good for providing maybe 10W of load.
My statements were made based on 50 years as an electronics technician, street rod builder, and bike builder. There's a big difference between watts and ohms. A 5 ohm resistor would be adequate but would draw even more power than a 6 ohm resistor. If I had it to do over, I would try a 50 ohm resistor first. But 50 WATTS of power handling capacity is the minimum to consider. Feel free to burn out all the five watt resistors you desire. The resistor industry needs the business and it might help reduce unemployment.
You don't specify the most inportant parameter which is resistance in ohms, this along with the maximum car voltage will determine the power used by the resistor. I used a 150 ohm resistor, at 15 volts that would be 1.5 watts used by the resistor. A 5 watt resistor at this value would provide a cooler running resistor than a 2 watt but you need to check whatever one you pick to make sure it doesn't get too hot in the environment it's mounted. To determine the value for my car I wired a small 10 turn wirewound potentiometer in parallel with the HID ballast and adjusted it until the headlight doors just started to work, about 220 ohms, then I replaced it with a 150 ohm resistor to ensure operation. There is no reason to add a low ohmic value resistor when the car computer thinks 150 ohms is the same as the old headlights. A ten ohm resistor for example will consume 22.5 watts at 15 volts. I used a 25 watt resistor only because I had one already and it runs cool.
LOL, a 50 ohm resistor will be dissipating about 4W maximum connected to the 14.2V maximum electrical system in the car. Why do you need a 50W resistor? A 5W resistor would be too small to ensure reliable operation, but a 10W resistor would be more than enough and it certainly would not quickly burn out. Maybe you forgot the basics during your 50 years of being an electronics technician?
A 100ohm, 5W resistor will work fine for this purpose.
You are correct about everything other than my specifying the value of the resistor - I stated that I used a 6 ohm resistor. Your use of a pot to discover the threshold needed to fool the ECM is valuable - thanks!
Who said anything about a 50 ohm resistor in the original post? The whole point of the original post was the tendency to confuse ohms with watts, which you just did...
THANKS FOR THE CLARIFICATION! I offered the post as a help to those who have been trying to get their headlight actuators to work right and have been confused by previous posts. I've said all I need to say on the subject and I'll leave it up to you guys to work out the details on resistor ohmage. I intend to try the 150 ohm resistor myself. Thanks for the tips guys!
OK, you posted nothing about the resistance in the first post but you did manage to post about 50ohms in your second post.
I have never confused ohms with watts. But apparently, me posting that you need to install a resistor to dissipate 2W of power is confusing to you.
Lets see, I have 14.2V and want to apply a 2W load. 14.2^2/2 = 100 ohms. So, I am recommending 100 ohms. I wouldn't recommend using a 2W resistor for 2W of power, so use a 5W resistor to be safe.
Simple, right?
Also, for the record. your only mention of 6 ohms was this which really says nothing about the resistor you actually used or that this is the ohms needed.
