c5 headlight assembly
Old Oct 20, 2011 | 07:45 PM
sparklerman's Avatar
sparklerman
1st Gear
Default c5 headlight assembly
can any one tell me what other years will interchange with a c5 headlight assembly? I have a 2000 and need to find out. I have heard 97-04 but also that 00-01 are only interchangeable. Thanks, Jerry sparklerman@bex.net
Old Oct 21, 2011 | 07:54 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I really don't know unless you start checking GM Part numbers. I suggest you contact Gene Culley at www.gmpartshouse.com as he can probably tell you right away. He's the best parts guy around.
Old Oct 22, 2011 | 02:36 AM
striper's Avatar
striper
I don't know why all C5 headlights shouldn't interchange since they look and work all the same. I've had a '98 and now an '03 that I've done work on both. There were no visible reasons to suspect they were different assemblies. The only thing I know that was changed is the black bezel that fits around the headlight.
To c5 headlight assembly
