Battery Tie Down Bolt Size
Old Oct 20, 2011 | 08:51 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
Default Battery Tie Down Bolt Size
The previous owner removed it and Im going to need it for AutoX
I bought one of those side ones with a bolt from Advance auto, but the bolt they supplied isnt the right size. What size bolt is it?
Old Oct 20, 2011 | 09:00 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I'm not 100% sure on the thread size, but I know the head is 1/2in...hope that gets you going in the right direction at least.
Old Oct 20, 2011 | 09:03 PM
lucky131969's Avatar
lucky131969
Not sure what you mean by "tie down"..if that is some kind of different strap or something?
The factory battery hold down bolt is a M8x1.25x55
Old Oct 20, 2011 | 09:06 PM
rtpassini's Avatar
rtpassini
wrong terminology. A lot of batteries are held down by a "T bar" or tie down that goes over the top with J hooks. Vettes obviously use the side hold down thingy. my brain is fried, I cant think of anything tonight!!!
But thanks for the info on the bolt!
lucky131969
1/2 inch? It's metric.
Old Oct 20, 2011 | 09:07 PM
lucky131969
No biggie. Good luck with the rest of the work
Old Oct 20, 2011 | 09:40 PM
Antvette's Avatar
Antvette
I guess mine is different then cause I removed it the other day and the 1/2in worked flawlessly.
Old Oct 20, 2011 | 10:02 PM
dndrsn's Avatar
dndrsn
8mm bolt has a 13mm head. 13mm = .512 in. that's only .012 in.
bigger than 1/2 in. 1/2 in. socket would fit.
Old Oct 20, 2011 | 10:03 PM
lucky131969
The C5 is dimensioned in the metric system, so yours is not different. If my memory serves, the bolt head is 13mm, so if you have a sloppy 1/2 socket, or a worn bolt head....yes, the 1/2 inch socket will work.
12.7mm = .5 inches
Old Oct 21, 2011 | 10:11 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Yes, 13mm is the correct size of the bolt head.
To Battery Tie Down Bolt Size
