Ported Throttle Body Problem! HELP!!
Old Oct 21, 2011 | 09:04 AM
McAllister513's Avatar
McAllister513
Default Ported Throttle Body Problem! HELP!!
Ok I have tried to search and still haven't gotten a clear answer! I took my intake and throttle body off for cleaning the other day and I got everything clean! And I really didn't even port it I just used sandpaper to smooth out the outer lip! Didn't touch the inner blade with sandpaper. And at first my car would idle rough and rev by itself so I went to a buddies and he found that I had a vacuum leak behind the intake so I thought it fixed my problem and it didn't until I got half way home! Now my car will idle fine and run fine but it revs up and drops back down to normal while i'm at a red or just sitting still! What could be wrong now? I checked for leaks and found nothing, did the idle relearn and still same ole thing! Plz help!
Old Oct 21, 2011 | 09:16 AM
dougbfresh's Avatar
dougbfresh
Loose electrical connections-see if there are any codes 1st.
Old Oct 21, 2011 | 09:26 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
did you replace the intake port gaskets?
Old Oct 21, 2011 | 09:50 AM
McAllister513
Checked all connections and all is good & no codes!
Replaced all gaskets!
Could this be a throttle position sensor?
Old Oct 21, 2011 | 09:54 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
sounds like you still have a leak. start the car and use some carb & choke cleaner, GENTLY spray around the tb & intake, if it revs high where you sprayed you just found your leak.
you can hog out the TB pretty good, did you happen to take the blade out? if you don't have it in there right it could act goofy
Old Oct 21, 2011 | 09:56 AM
McAllister513
I did exactly that last night and got nothing! I did take the blade out to clean it but I took pictures to make sure I put it back together the same!
And it only does it sometimes not all the time lol
Old Oct 21, 2011 | 09:57 AM
87SAM's Avatar
87SAM
Have you checked for codes yet?
Old Oct 21, 2011 | 10:28 AM
McAllister513
Can drive the car as long as you want with no codes!
Old Oct 21, 2011 | 10:39 AM
87SAM's Avatar
87SAM
I was confused when I first posted but now I understand, no codes when using the DIC.
Old Oct 21, 2011 | 10:50 AM
cdkcorvette7's Avatar
cdkcorvette7
You know your codes aren't going to just pop up right? You have to pull them out of the DIC...
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Oct 21, 2011 | 12:10 PM
McAllister513
I know how to get codes! And their are none!
Old Oct 21, 2011 | 02:32 PM
Jnape's Avatar
Jnape
Did you disconnect the battery while doing the work? It does take a bit to relearn fuel trims.
Old Oct 21, 2011 | 03:10 PM
McAllister513
Ok so while on break at work I put a new TPS sensor on and got a can of carb cleaner an sprayed it all around te intake and even behind the intake where the bigger lines are an even around the throttle body and nothing do I can ruled out vacuum leak! Either it hasn't adjusted to the fuel trims or I have messed up my throttle body!
Old Oct 21, 2011 | 03:38 PM
dougbfresh's Avatar
dougbfresh
I'm guessing the TB is fubar'ed
Old Oct 21, 2011 | 09:50 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
is the fine wire in the MAF broken? that sucker is fragile as hell; cannot be rough handled...it's platinum or palladium, I can never remember which...
Or, farther up stream you have a loose connection at one of the silicone rubber connections messing up your fuel trim settings while the engine is running at low rpms
Old Oct 22, 2011 | 11:38 AM
McAllister513
Well I guess I'll be pulling my intake back off to check things out! I replaced the intake gaskets last time! Can I reuse them again!
Old Oct 22, 2011 | 11:41 AM
87SAM's Avatar
87SAM
Yes
Old Oct 22, 2011 | 01:38 PM
McAllister513
Is it possible I could have a leak becuz I overtightened the intake bolts! I just tightened them in the correct sequence but didn't have a torque wrench that small!
Old Oct 22, 2011 | 02:41 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Perhaps you cracked it from over tightning.
To Ported Throttle Body Problem! HELP!!
