clutch noise
Old Oct 23, 2011 | 10:22 PM
ly n low's Avatar
ly n low
Default clutch noise
Ever since I have traded my stock clutch for an aluminum Fidanza flywheel and Centreforce clutch I get this bad noise when I let the clutch out ,it sounds like a bad screeching noise very noticeable.I am not sure if it is the release bearing or something else.Has anybody heard of any problems with the lighter flywheel and a dual friction clutch ?The sound is only when you release the clutch in first gear only..Any help is appreciated
Old Oct 25, 2011 | 09:51 AM
ly n low's Avatar
ly n low
ttt
Old Oct 25, 2011 | 10:20 AM
MStrahan's Avatar
MStrahan
I get some of that but only if I haven't driven it in a while and I try and really ease into first gear. I have full bolt ons and a Diamond stage 2 clutch with lw flywheel.
I've noticed that if the sound happens and I'm able to do a couple of high rpm shifts that it will go away for quite a while. I don't think it's a big deal. Pretty sure it's just some chatter. Also, I had to learn to give the car a little more throttle when taking off with the lw flywheel.
Hope that helps.
To clutch noise
