Need a C5 expert's help (pics)
Old Oct 25, 2011 | 02:56 AM
Lothar34's Avatar
Lothar34
Why do you want to evac the high side?
Old Oct 25, 2011 | 03:02 AM
Vicarious.'s Avatar
Vicarious.
Don't I need to, in order to pull the compressor bracket off? I am a first timer on automobile A/C systems, if you couldn't tell already.
Old Oct 25, 2011 | 11:23 AM
Lothar34's Avatar
Lothar34
Oh yeah, I didn't know you were going to pull the bracket off already. I thought you were going to add the dye and see if you could determine the leak spot.
Yeah you're not supposed to vent the refrigerant to the atmosphere, but you certainly wouldn't be the first person to do it...
Old Oct 25, 2011 | 01:16 PM
ShootCraps's Avatar
ShootCraps
Originally Posted by kh400
I think you are going to need a new A/C compressor. Fairly common problem on the C5. A bitch to change also. Good luck!!!
My brother and I replaced the compressor in my C5 a couple weeks ago. Took 6 hours and was not difficult. Only annoying thing is removing the water pump. Get the instructions from the forum and follow them. Good luck.
