Active Handling Service Vehicle Warning
Old Oct 24, 2011 | 11:35 PM
Ironman433's Avatar
Ironman433
Default Service Active Handling Warning - Brakes Locking Up
I'm having some Active Handling issues with it engaging when I hit the brakes occasionally. It will lock the brakes up for a bit - or at least that's what it feels like... Not completely and only briefly - and then give two warnings on the DIC - Service Active Handling and Service Vehicle Soon. Any idea what's up and where to start fixing that?
These are the DTC Codes that came up:
28-TCS
H C1281 Steering Sensor Uncorrelated Malfunction
H C1287 Steering Sensor Rate Malfunction
40-BCM
H B2578 Right Front Turn Signal Monitor Circuit
H B2583 Left Front Turn Signal Monitor Circuit
60-IPC
H B0521 Tachometer Signal Circuit Malfunction
99-HVAC
H B0361 Left Actuator Feedback Short to GND
H B0367 Right Actuator Feedback Open
H B0441 Left Actuator Out of Range
BO-RFA
H/C C2120 TPM System Malfunction
C C2121 TPM System Programming Malfunction
Last edited by Ironman433; Oct 25, 2011 at 01:49 AM. Reason: Better explanation of problem
Old Oct 25, 2011 | 07:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You've started two threads with the same issue. Please ask a moderator to delete one.
