Do these Spark Plugs look normal???????????
Old May 5, 2002 | 02:25 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Do these Spark Plugs look normal???????????
Decided to pull the plugs while I was installing the Headers and :confused: these just don't look right. Doesn't this gap seem a little wide??????????? BTW .............what are most of you using on a stock motor.................TR 55's
[Modified by Mag Red Monster, 12:25 PM 5/5/2002]
Old May 5, 2002 | 02:42 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Do these Spark Plugs look normal??????????? (Mag Red Monster)
Looks a little wide. Do you have a feeler guage?
I use NGK TR55's.
Eric
Old May 5, 2002 | 03:03 PM
F8LPONY's Avatar
F8LPONY
Default Re: Do these Spark Plugs look normal??????????? (66ImpalaLT1)
Looks like the eletrode is burned down. I bet those are stock plugs or been in there awhile huh?
If so then the electrode wear down and eventually you will increase the gap form the lost material.
I use NGKs also. TR5s and TR6s depending on the vehicle.
Old May 5, 2002 | 03:27 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Bob yes that's a large gap. (from what I can see) They should be at 57. I just went to Rapid Fires on Thursday and gapped those at 50. Runs like a top. :D
Bob
Old May 5, 2002 | 03:40 PM
Mag Red Monster
Elite Member
I use NGK TR55's.
Eric
Avctually they were gapped at .060 Sure looked like a 1/4" to me. Now I can't find any in town :cry I've called 6 places and the most I can find is 5 :mad
Old May 5, 2002 | 04:25 PM
F8LPONY's Avatar
F8LPONY
So replace those 5 that are heard to get to and replace the others when they come in. Won't hurt anything. :)
Old May 5, 2002 | 08:16 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: Do these Spark Plugs look normal??????????? (F8LPONY)
Hey, can't hurt :yesnod:
(Gap at .050)
Old May 5, 2002 | 10:39 PM
TLewis4095's Avatar
TLewis4095
Looks like stock platinums with the puc missing.......
Old May 5, 2002 | 10:43 PM
Z51BOB's Avatar
Z51BOB
Default Re: Do these Spark Plugs look normal??????????? (TLewis4095)
I see an electrode there, but.. it looks like .080 to me. A little wide. Time to change for new platinum. :nopity
Old May 5, 2002 | 10:45 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Do these Spark Plugs look normal??????????? (Z51BOB)
I switched to TR-55's when I installed my headers as well. My stock plugs looked similar to yours. Certainly won't hurt anything to change them out.
Old May 6, 2002 | 12:41 AM
Mag Red Monster
Elite Member
Default Re: Do these Spark Plugs look normal??????????? (rschiltz)
Hey Rick.............did you put the metal shields back on the wire ends when you swithed to the Taylor wires?????
Old May 6, 2002 | 12:42 AM
MDL-01C5's Avatar
MDL-01C5
I didn't use them with my MSD's, and have had no prob's :)
Old May 6, 2002 | 12:56 AM
Mag Red Monster
Elite Member
Default Re: Do these Spark Plugs look normal??????????? (MDL-01C5)
Thanks :cheers:
Old May 6, 2002 | 01:23 AM
MelloYellow's Avatar
MelloYellow
I think TR5's are the same plug gapped at .050 instead of .055 for the TR55's. I'd confirm with NGK.
Old May 6, 2002 | 01:33 AM
QWKAZEL's Avatar
QWKAZEL
Default Re: Do these Spark Plugs look normal??????????? (MelloYellow)
blurry pic
Old May 6, 2002 | 01:49 AM
bruce1's Avatar
bruce1
Yes, a Wide gap...................too wide...indeed
To Do these Spark Plugs look normal???????????
