Good Gawd I need some header installation help!
Old May 5, 2002 | 04:42 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Good Gawd I need some header installation help!
OK..I have everything apart. Passenger side.....starter off, coil pack removed and I stll can not get these Belangers to dop in from the top. :mad Any ideas????????????????? Drivers side.............forget about it! :mad Am I going to have to raise the engine to do this????? I'm starting to get a bit perturbed. :(
[Modified by Mag Red Monster, 2:42 PM 5/5/2002]
Old May 5, 2002 | 04:53 PM
Supercharged's Avatar
Supercharged
From: 26 NM out the 304 radial of the ORD VOR Illinois
Default Re: Good Gawd I need some header installation help! (Mag Red Monster)
I had to remove the valve covers to get the B&B shorties in from the top.
Old May 5, 2002 | 04:57 PM
Mag Red Monster
Elite Member
Default Re: Good Gawd I need some header installation help! (Supercharged)
Never thought about that yet...............I'm hoping some one that has done these will reply.
Old May 5, 2002 | 05:05 PM
wwashing's Avatar
wwashing
Give Nate at XTREME a call in the morning. I bet he'll be glad to tell you how to do it without disassembling the engine.
Old May 5, 2002 | 05:13 PM
Supercharged
Default Re: Good Gawd I need some header installation help! (wwashing)
the valve covers are super easy to remove/install...try it.
Old May 5, 2002 | 05:20 PM
Mag Red Monster
Elite Member
Yeah I was planning on that but you know how it is when you get a project started................... Nothing is working out today :lol: Oh Well..at least it's sunny and warm out
Old May 5, 2002 | 05:43 PM
Patman36's Avatar
Patman36
Isn't that normal for a guy? I mean, we like to THINK we can do things... :D :D :D
Patrick :cheers:
PS. Congrats on the non-smoker lifestyle! :cheers: :seeya
[Modified by Patman36, 3:44 PM 5/5/2002]
Old May 5, 2002 | 05:44 PM
yelloz06's Avatar
yelloz06
WOW, on my 02 Z, the only things I removed were the coil packs for my shorty install :eek:
Old May 5, 2002 | 05:57 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Default Re: Good Gawd I need some header installation help! (yelloz06)
Drivers side... leave all the crap on (alternator, valve covers, etc.. and put the header in from the bottom.. super easy.!
Passenger side .. remove valve cover, coil packs, and spark plugs.. drop header in from the top. no need to drop the starter..
I've put on 6 or so sets this way, works for me. Just my .02
Old May 5, 2002 | 06:25 PM
Mag Red Monster
Elite Member
Default Re: Good Gawd I need some header installation help! (nevrenuf)
Passenger side in and bolted :D :cheers: Hey on the drivers side how the hell high do ya need to get the car in the air? I'm working on jack stands here :lol: I'm hoping Belangers are no different than the others. BTW ......if anyone wants to call and offer some tips.........the installation hot line is 513-703-5383 Bob
[Modified by Mag Red Monster, 4:26 PM 5/5/2002]
Old May 5, 2002 | 07:05 PM
C5Noir's Avatar
C5Noir
To get the driver's side in from the top, remove the following:
Fuel rail cover
Coil pack
Alternator (2 bolts)
Valve Cover
Air Tube
Steering shaft nut at the base (13mm)
Then, just move the steering shaft out of the way by putting it parallel almost with the windshield washer reservoir. Should drop right in. Worked for me the past 4 times :)
Old May 5, 2002 | 07:49 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Default Re: Good Gawd I need some header installation help! (C5Noir)
Levi -- good catch, I do unbolt the steering shaft coupler..
Tom
Old May 5, 2002 | 09:55 PM
Mag Red Monster
Elite Member
Tom
:smash: Well I wish I would have seen this first. :lol: Actually they slipped right in from the bottom after I got a helping hand. Interesting was the fact that the most forward header bolt on both sides was a little tough to tighten. Felt like I was going to break the darned thing. Even had anti-sieze on them.
Old May 5, 2002 | 09:57 PM
C5Noir's Avatar
C5Noir
Good job, MRM. BTW, how high off the ground did you have your car?
Old May 5, 2002 | 10:36 PM
TLewis4095's Avatar
TLewis4095
Removeing valve covers is a must...and the trick to the drivers side is use a 4' long 2x2 to pry up the front side of the engine (the motor mounts give a little) and they slip right in!
Old May 5, 2002 | 10:51 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Good Gawd I need some header installation help! (TLewis4095)
Are they on yet?
Old May 6, 2002 | 12:38 AM
Mag Red Monster
Elite Member
Default Re: Good Gawd I need some header installation help! (rschiltz)
Are they on yet?
Yep! :D Just now came in from the garage. :crazy: Everything is tightened up. Tomorrow I'll install some new plugs then fire it it up. :yesnod: I have a muffler shop right down the street fabricating the connection to the cats. Might have ben easier if I had the small piece that bolts to the headers but I bought these used so I guess begger can't be choosers.
Old May 6, 2002 | 01:24 PM
ghost.rider's Avatar
ghost.rider
EXCELLENT :cheers:
nOW GEt oUT THerE anD BUy YOur daUGHTer THat
CeLl phONe FOr heR BiRtHdAy
:smash:
To Good Gawd I need some header installation help!
