C5 Handbrake Finally Works
Old May 5, 2002 | 06:34 PM
Red C5's Avatar
Red C5
Default C5 Handbrake Finally Works
We all know how wonderfull our handbrakes are. :rolleyes: Mine actually broke, the ratchet system. The dealership installed a new one. It sounds different, feels a little different, and it actually works. If I park my car on a hill, it doesn't move! If you're having problems with yours, this may the fix.
[Modified by PeterC, 2:34 PM 5/5/2002]
Old May 5, 2002 | 07:53 PM
99 Corvette's Avatar
99 Corvette
Default Re: C5 Handbrake Finally Works (PeterC)
Give it time this one will stop working too. I wouldn't trust the parking brake on a hill :cheers:
Jerry
Old May 5, 2002 | 08:06 PM
robsvette's Avatar
robsvette
Default Re: C5 Handbrake Finally Works (99 Corvette)
Jerry
i adjusted mine and it worked for a few months. it barely holds now :(
be sure that they are not touching after an adjustment. if you over do it, they may slightly grab while you're normally driving
Old May 5, 2002 | 10:40 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Another Corvette problem.
Old May 7, 2002 | 01:52 PM
Had the same problem with mine and they replaced the handle mechanism. Still needs to be adjusted though as I have to pull it to the top to get it to catch.
$45,000 car with a $2.00 parking brake. Got to love it.
Old May 7, 2002 | 03:54 PM
Butters00Vet's Avatar
Butters00Vet
Jerry
You guys make laugh. :lol: What faith we have in our cars. :boxing
Here's my little story. I was swapping cars and my buddy was sitting in the passenger side. I was in the garage and I had to get out to start the other car. So I stopped with the engine running, pulled up the E-brake and proceeding to get out of the car. Next think you know my buddy yells out, "DUDE YOUR CARS MOVING?" I turned around and saw my car slowly rolling towards another parked car. My friend was yanking on the E-brake as hard as he could but it wouldn't stop. I had to jump in and step on the brakes. Now mind you, the floor that I was on, has MAYBE a 2-3 degree incline at most. Now that's embarassing. I went back one night and brought a marble with me just to test the floor to see if it was maybe a higher incline... I dropped the marble on the floor.. and watched it roll maybe 3 feet and stop. The vette's E-brake is :bs.
Old May 7, 2002 | 04:54 PM
01C5fan's Avatar
01C5fan
I need to adjust mine. Doesn't hold unless it's a VERY slight incline. Works best when the back end is pointing down hill. I'm surprised there hasn't been more noise about this. You'd think the safety ***** at NHTSA would be all over it. Wouldn't be much fun if the hydraulics failed and you really needed it.
Old May 7, 2002 | 05:33 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Default Re: C5 Handbrake Finally Works (01C5fan)
I not sure why but mine seems to be grabbing more. I think it might have readjusted while I was backing up a pretty long distance.
Old May 7, 2002 | 06:19 PM
ghost.rider's Avatar
ghost.rider
Default Re: C5 Handbrake Finally Works (pjazz)
This is very interesting because my 99's and my neighbor's 2001's emergency brakes have always worked fine. If I park on a hill . I always put it in either reverse ( the recommended gear) or first and use the brake. But just for grins sometimes I will just set the barake and it has never moved while I wait a couple of minutes to see if it will slide or not. Of course before I get out I do put it in gear because I always :smash: do that with a stick if the motor is not running.
Old May 8, 2002 | 10:17 AM
ncvetteman's Avatar
ncvetteman
Mines never really worked either... just leave it in gear (MN6) and try to avoid inclines.
Old May 8, 2002 | 10:53 AM
C6VETTE4FUN's Avatar
C6VETTE4FUN
seems to grab less every time i hear that famous bang sounds everyone reports!
Old May 8, 2002 | 11:10 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: C5 Handbrake Finally Works (1997C5VTBOY)
Mine works, but I am as alway's worried it is going to fail and as I walk away I have to keeping looking back ready to make a run for it. What a piece of crap!
Old May 8, 2002 | 12:03 PM
ShanMan14's Avatar
ShanMan14
Cruise-In II Veteran
Cruise-In V Veteran
Default Re: C5 Handbrake Finally Works (Shinobi's97)
Mine doesn't work.
Old May 8, 2002 | 05:36 PM
tt427pacecar's Avatar
tt427pacecar
St. Jude Donor '05-'06-'07
Default Re: C5 Handbrake Finally Works (ShanMan14)
I've had the one in my '98 adjusted a few times, as well as having just about every part replaced. It'll work right for 3 months tops, slowly getting worse with each use. Now it won't even hold the car on level ground. :lol: I gave up on it 9 months ago. :rolleyes:
In my 2000, it worked well for 6 months, after that it started to fade as well. I found a fix that's 100% so far, a complete Dilusi brake replacement kit. Aside from the obvious improvement in braking, they also cured my e-brake problems. :yesnod: Now it works 10 times better than either car's e-brake did stock at it's best point. :p:
To C5 Handbrake Finally Works
