alternator volts
Old Oct 29, 2011 | 12:56 PM
hotparts's Avatar
hotparts
Default alternator volts
Hi guys,
how much volts must the alternator bring at 1000 rpm.
Is 13,3 volts not enough at cruising?
Could it be thet the fuel pump brings not enough fuel pressure when i have only about 13 volts?
Old Oct 29, 2011 | 01:27 PM
lionelhutz's Avatar
lionelhutz
13.3V is low at the alternator but the fuel pump should still be ok at that voltage.
Old Oct 29, 2011 | 01:48 PM
hotparts's Avatar
hotparts
What should be the right voltage?
Can i let the alternator repair or could it also have this voltage when the battery is nearly empty?
Old Oct 29, 2011 | 05:39 PM
lionelhutz's Avatar
lionelhutz
How are you reading the voltage?
Is the battery fully charged?
Peter
Old Oct 29, 2011 | 07:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Using a meter, at the battery with the engine running, you should see 13.8-14.3. With the engine off, you should see at least 12.5 or your battery is either done or discharged.
To alternator volts
