What is the highest stall converter I can use without Reprogramming on my 2001?
I want to do a yank 9" pro thruster 4400. With this work without setting codes?
Re: What is the highest stall converter I can use without Reprogramming on my 2001? (joe2gaan)
If you are running that car on the street I would not use a 4400 stall converter. When you start getting above 3500 on stall converters things get a little tricky. A stall converter is being stressed whenever it is not stalling or locking up. Ie, just easing from a stop light or any other stop. With 4400 rpm you would be getting into a zone that is slightly high for street / everyday driving. I have another car with 3000 stall converter actually a Jeep Grand Cherokee with 550hp at the flywheel and 3000 is just right. Not sure about the codes.
Re: What is the highest stall converter I can use without Reprogramming on my 2001? (Buckmaster)
With tuning do you think i could mask the stall speed by making the converter lock up during light throttle, and act normal under full throttle? Can Ed Right do this?
1 Post
Cruise-In II Veteran
I think changing gears is a much bigger driver for programming work than the converter alone. You can definitely tweak shift points and lock up to hide it a bit but you generally shouldn't be throwing codes with just the converter swap. The slip tests really only come into play under conditions when the stock converter would be locked.
I wouldn't go that big unless you really want a drag car and have the power band and tire/suspension for it. Would be fun though...
Re: What is the highest stall converter I can use without Reprogramming on my 2001? (ToplessTexan)
I was wondering if there was a way you could make the converter lock up at a low speed like 1 or 2 mph and unlock during shifts and lock back after shifts when under light throttle, but act normal during full throttle. Is this possible? Thanks for your help.
Joe
Joe
Received 2,053 Likes
St. Jude Donor '13
I remember some posts from last year where the 2001 cars were supposed to be much more sensitive to getting slip codes from a higher stall converter, than previous years. I think the concensus was that anything above about 2,500 stall you might get a code. Anyone know for sure?
1 Post
You can adjust TCC locking via programming quite easily or if you're up for something more ghetto you could wire in a switch to trigger lock up manually. :crazy: The stock programming does not hold TCC lock through shifts.
I'd suggest talking w/ Mike at Yank about your particular application.
My 3500 rpm Vigilante was installed 2 weeks ago and I have no codes.
Only problem is massive loss of traction with run-flats!
:D :D :D :D :cheers: :cheers: :cheers:
