My '89 keeps overheating - HELP!
The car overheated on me the first time late last summer. It didn't bother me so much since I was putting it away for the winter anyway. During the winter, I changed the thermostat, the upper hose, flushed the rad, and put in new GM coolant (the green stuff). I just took it out today, and while idling the temperature climbed to normal, with the fans cycling on and off as they normally should. But when I got the car on the road, the temperature started to climb very high (130C or about 260F). Both fans were on, but they weren't dropping the temperature. I turned around and headed back home. When I hit the driveway, I turned the car off immediately and popped the hood. There was coolant all over the passenger side under hood - no doubt from the coolant overflow bottle which was bubbling pretty baddly.
I should also mention, while the car was idling, there was considerable white smoke pillowing out the exhaust pipes, accompanied with a weird smell. This smoke went away as the car warmed up, so I figure it's probably a combination of both moisture in the exhaust system and in the gas tank - the car was stored with very little and VERY old fuel in it all winter (a mistake, I know). I thought that it might be a sign of burning coolant, but there's nothing in the oil.
I'm totally stumped, and what's worse my cousin wants to use the car for his wedding in 2 weeks.
HELP!!! Anybody have any ideas at all? :confused:
