Disable CAGS with HP Tuners
Anyone know what values to set the following parameters in order to disable CAGS:
M6 C.A.G.S. (Computer Aided Gear Selection aka Skip Shift)
The parameters control the Computer Aided Gear Selection (CAGS or “Skip Shift”) feature of the VCM. It activates a solenoid in the transmission to force shifting to 4th gear under light throttle conditions. If disable TPS is exceeded then the solenoid will not activate.
Disable %TPS: Throttle Position to disable C.A.G.S. routine
Enable Speed: Speed to enable C.A.G.S. routine
Disable Speed: Speed to disable C.A.G.S. routine
Enable Baro: Baro to enable C.A.G.S. routine
Disable Baro: Baro to disable C.A.G.S. routine
Min Coolant Temp: Minimum Engine Coolant Temp required for C.A.G.S. routine
(sorry for the double post in Z06 section)
Peter
