Driver's side fan not working, Code P0480 coming up.
I have been getting a check engine light lately, the code is the P0480 which is the Fan 1 relay. I have read all 115 threads on this code. SO I am getting a little information overload.
Last night I warmed the car up and checked the fans. The passenger side fan was running, the driver's side was not. I have looked at the fuse box and all relays and fuses look clean and healthy. But I haven't had a chance to check them electrically. The fan turns freely. There has been some work done on the car recently and the motor plug wires may have come in contact with the swaybar. But I haven't noticed any break in the insulation.
As I mentioned I have used the search function. But with only one fan running and the code, I figured some of the experts would be able to narrow down the problem ( as in which fuses and relays).
Thanks in advance. Seriously how di we fix our cars before the internet?
Here is the wiring diagram for the cooling fans for the C5:
In low speed operation the fans are wired in series and BOTH fans are supposed to run at half speed (because the 12 volts is divided across the two fans with each fan seeing approximately 6 volts). If you can read wiring schematics you will be able to see that from the above diagram. I am assuming that the running fan IS IN FACT AT LOW SPEED. If it is running in HIGH speed then the info below does NOT apply to your problem. So assuming the single fan is in low speed mode continue below....
Your description says left fan not running, right fan running in low speed mode. That tells us the relay 45 and fuse 46 are OK. It also tells us that the relay 44 is in the normal position (ie relay 44 is not activated) with 12 volts passing through point B11 to the top of the right fan motor. It also tells us that the ground point G102 is OK. If this were not so then the right fan could not operate.
Since the fans are connected in series for low speed operation, the left fan must be bad but still electrically in the circuit in order for the fan right to operate. Left fan replacement is indicated.
What you are saying makes perfect sense. The question then becomes was the right fan turning at slow speed. Hard to determine since it has been tuned. I know the original aftermarket tune turned the fans on early. The fan was blowing well, but it didn't push my hand back (I've seen fans blow harder). Some how I will see if I can check the motor.
You can check the left (or right) fan motor relatively easily. Disconnect the harness connector for the left fan. Then apply 12 volts to the pins that go to the left fan. Obviously if the left fan fails to spin it is bad.
Is it true that after the engine is turned off, the fans run for a short time?
Find out what temperature settings your tuner put in for the low fan and the high fan.
Then, you can watch the temp and the fan and see what temp the working right fan comes on. I suspect the right fan is coming on when you hit the high fan turn-on temp setting.
The likely suspects are fuse 49, relay 45 or the fan motor.
Peter
I just read on here that if I pull relay 43 the fan won't work if it's in high speed mode? Also which relay should I switch if I want to check if the relay is bad (which is the fog lamp relay?).
Thanks a lot guys. Fuse #49 was open. To be proactive I switched #43 and #45 relay, and the right fan continued to run. So I will replace the the fuse and go from there. Now I'm wondering what blew the fuse?
Yeah, you can't cool the engine if the coolant isn't circulating so you might cool the under hood components a little bit by running the fans but that's about it.
I have a cooling fan problem. I bought 2 new mini relays. They have polarity. I need info on how to install. A picture of a 1999 underhood fuse box would help...
There are 3 relays: 43, 44, and 45. 44 is different from 43 & 45, and can only be installed one way(idiot proof). 43 & 45 can be installed in either orientation, but other relays or fuse may prevent that.
Thanks for quick reply! I bought all three. Yep 44 is a5 pin. No explanation needed. The other two are mini switches right.? It seemed to have polarity. But I can install them either way? And do you know what temp they should kick on? I bought this Vette used and some idiot hard wired the fans to start when the key is in the 'on' position!!
