Drive Shaft Coupler failure
Old Nov 2, 2011 | 05:14 PM
FKING1's Avatar
FKING1
Default Drive Shaft Coupler failure
What are symptoms of Drive Shaft Coupler failure?
Have a 2000 manual, highly modified with about 475 HP.
Have a clunk noise in the rear when hitting a bump.
Have checked sway bar, shock mounts and all suspension parts and they are tight.
Old Nov 2, 2011 | 05:54 PM
bumble-z's Avatar
bumble-z
Cat back where it crosses over the axles?
" " comes close to the differential?
Differential nuts loose where it attaches to cradle?
Broken rear shock?
Ball joint?
C/arm bushing?
Are you sure the sway bar is not broken where it attached w/the U shaped clamp?
I would think the coupler if bad would stay in tune with the the rpm's
when moving & not when hitting bumps.
Old Nov 2, 2011 | 06:31 PM
cdkcorvette7's Avatar
cdkcorvette7
Broken rear shock?
Ball joint?
C/arm bushing?
failed couplers would feel and sound like driving over rumble strips at anything over 50 mph.
Old Nov 3, 2011 | 05:01 PM
FKING1's Avatar
FKING1
Thanks for tips. Maybe not coupler.
Will further inspect.
Shocks not broken and sway bar intact.
Old Nov 3, 2011 | 06:29 PM
bumble-z's Avatar
bumble-z
There has recently been posts by a few members with older C/5's reporting of original sway bars cracking right in the area where it bolts up.
To Drive Shaft Coupler failure
