Alternator pulley fell off
Old Nov 5, 2011 | 07:05 PM
TRDon's Avatar
TRDon
Default Alternator pulley fell off
Between quick shifts, I lost the nut that holds on the pulley, the pulley came off the shaft, but the pulley stayed in the engine bay. Putting the pulley on the alternator, it bottoms out on the bearing hub and has no friction. Is this a press fit pulley or is the nut expected to do all the work. I guess I need to know where to go from here, just a new nut, a new pulley, or a new alternator (shaft). I was suprised to see it didnt have a keyway on it.
It is on a 2002 LS1 M6 with a TVSS2300
Old Nov 5, 2011 | 08:18 PM
lionelhutz's Avatar
lionelhutz
It's not a press fit and there is no keyway. Just crank the nut down tight. Best to hit it with an impact.
Old Nov 5, 2011 | 09:59 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Impact gun, use RED Loctite on threads with a lock-washer between nut and pulley !!!
Old Nov 5, 2011 | 10:26 PM
TRDon's Avatar
TRDon
Awesome, Thanks guys Now the big question, what is the thread size on the nut? Long shot I know, But I figured I would ask.
Old Jun 19, 2012 | 01:39 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
I know this is an old thread but I figured I would add to the info and maybe help someone in the future. I installed my alnernater pulley(8 rib) with an impact gun and I guess I hit it to hard and stripped the threads off the alternater input shaft. I don't know I stripped them at the time but after a couple miles with the supercharger installed the pulley came loose and threw thr belt off and messed up the pulley. now I have to buy a new belt 95$, alternater150$, and new innovations west pulley $95. when I install my new pulley on my new alternater, I'll look tight it and used a lockin washer. DONT LET THIS HAPPEN TO YOU !
Old May 12, 2017 | 07:21 AM
Snocoon's Avatar
Snocoon
I just had this happen on my C6 z06 a quick downshift to 3rd from 6th and leaned into it. When I backed off I heard the nut bounce around the engine bay but the pulley was sitting on the brake lines. The size of the nut was an M16x1.5 if I would've known this size it would have saved me calling up a tow truck...
Old May 12, 2017 | 07:40 AM
runner140*'s Avatar
runner140*
Old May 12, 2017 | 06:28 PM
Snocoon's Avatar
Snocoon
Or tack weld the nut to the alternator shaft. Or a full bead...
Old May 13, 2017 | 04:02 AM
Rob 02's Avatar
Rob 02
The later ones had a clutch pulley for this reason. It s like a ratchet so it doesn't jerk the alt. There is a special tool for putting one on.
To Alternator pulley fell off
