Blackwing Install question
Old May 6, 2002 | 01:18 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Default Blackwing Install question
I just installed my new Donaldson Blackwing on my Y2K coupe and WOW what a difference it makes!!! I'm hoping someone can help me with my question. When i did the install, I couldn't get the air bridge to seat properly on its grommets. Is this normal or did I do something wrong? The air bridge sits up too high. :confused: :confused:
Old May 6, 2002 | 01:45 PM
willsco's Avatar
willsco
Cruise-In III Veteran
Default Re: Blackwing Install question (jw38)
It took a lot of work for me to get the bridge to sit on the grommets, but eventually I got it on there. :cheers:
Old May 6, 2002 | 01:46 PM
90 droptop's Avatar
90 droptop
On my 99, after much pushing and adjusting, it all fit together properly.
Old May 6, 2002 | 03:20 PM
QWKAZEL's Avatar
QWKAZEL
Default Re: Blackwing Install question (90 droptop)
Old May 6, 2002 | 03:33 PM
DsC5's Avatar
DsC5
Default Re: Blackwing Install question (willsco)
Old May 6, 2002 | 04:12 PM
gmmerc5's Avatar
gmmerc5
Someone on this board said that to get the air bridge to seat properly on its grommets, it help to apply some sort of grease inside the rubber grommets, this will help the air bridge to slide in easily.
I am thinking of buying a Blackwing too.
Old May 6, 2002 | 08:19 PM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Default Re: Blackwing Install question (gmmerc5)
You can use vasalene,wd-40,silicone spray,dielectric grease on the grommets and push down on the air bridge and the grommets will seat.I just recently pulled the Black-Wing off my 2000 and this worked.
HEB PS- the Black-Wing is on sale on the mall,check it out.
[Modified by HEB, 6:23 PM 5/6/2002]
Old May 6, 2002 | 08:30 PM
jmcassin's Avatar
jmcassin
Default Re: Blackwing Install question.HELP HELP HELP
I just got my slightly used blackwing from InPursuit1654, I sent him an email. When I went to install it today, I think that i am missing one thing....a coupler of some sort from the blackwing to the maf. Do you use the existing one or do you need to purchase one. If so whos got one that can get it to me by thursday.
thanks
jim c
Old May 6, 2002 | 08:57 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
What he said. :D It will go on eventually.
Old May 12, 2002 | 10:17 PM
GRAYVETTE's Avatar
GRAYVETTE
The air bridge grommets fit on plastic studs mounted on the top radiator shroud. This is plastic and moves. I found that if you support the shroud with your fingers and sort of move it up towards the air bridge the whole process is easier. At least it worked for me.
To Blackwing Install question
