Headlight gear broken how can i keep it up?
Old Nov 8, 2011 | 08:43 PM
niteriderc5's Avatar
niteriderc5
Default Headlight gear broken how can i keep it up?
Finally found a reason to go fixed...but problem is i need to wait for shipping...since this is andaily driver how can raise the pop up if the gear is toast....and yes the manually turning the **** is useless!
There just has to be a way to keep this open while i wait for new parts
Old Nov 8, 2011 | 10:26 PM
lionelhutz's Avatar
lionelhutz
Try taking the arm off and rotating the motor 1/2 turn. You may have to force it to open as your turn the manual **** until it catches.
Peter
Old Nov 9, 2011 | 07:46 AM
sereneDelusions's Avatar
sereneDelusions
When my passenger side gear went out I found only one side had the teeth ground down and wouldn't catch. I also removed the headlamp motor fuses to keep lights in the up position.
Old Nov 9, 2011 | 10:51 AM
rebelheart's Avatar
rebelheart
viagra???????
Old Nov 9, 2011 | 11:43 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by rebelheart
viagra???????
you beat me to it We are a sick bunch...
To Headlight gear broken how can i keep it up?
