What should my Max Engine RPM be?
Old Nov 10, 2011 | 09:24 PM
IDM's Avatar
IDM
Default What should my Max Engine RPM be?
Right now it is set at 6200 but what are all of the factors that have gone into that?
The engine is a low compression 9:1 346, with heads and a blower cam as well as a v2 S trim supercharger.
Does it depend on the heads/cam, the springs?
cam specs Blower Cam 224/228 591/591 @ 116. The heads are ported LS6.
Also what is the highest rpm you would suggest spinning a Vortech V2 supercharger?
Thank you all.
Old Nov 11, 2011 | 10:33 AM
IDM's Avatar
IDM
ttt!
Old Nov 11, 2011 | 10:51 AM
Tech's Avatar
Tech
http://forums.corvetteforum.com/c5-g...should-be.html
Old Nov 11, 2011 | 01:42 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
As far as the eng goes -it depends on your cam--Typically where the eng quits making MORE power and begins to make less--is where you would want to shift at---More duration raises the HP band-
As fa ras your blower---talk to them directly--I'd follow their reccomendations exactly---
To What should my Max Engine RPM be?
