Cooling Fans 2001
Old Nov 12, 2011 | 07:02 PM
hgoodwiniii's Avatar
hgoodwiniii
Default Cooling Fans 2001
Hi all, I seem to be having a cooling fan problem The fans are only running low speed. I changed all the fan relays and still only low speed even when the temperature gauge reads well above 220 degrees. The fans run hi speed when I connect directly to a fused power source. Any ideas what the problem could be?
Old Nov 12, 2011 | 07:25 PM
lionelhutz's Avatar
lionelhutz
The stock setting for high fan is 236.
Old Nov 12, 2011 | 07:26 PM
lucky131969's Avatar
lucky131969
Did you check fuses 14 and 46?
Old Nov 13, 2011 | 04:50 PM
hgoodwiniii
Yes fuses are good. I'll make sure the temperature gets above 235 degrees and see what happens. Thanks.
To Cooling Fans 2001
