Off Road X-pipe
Old May 6, 2002 | 08:04 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Off Road X-pipe
Hello,
Is this really capable of giving 15hp and 17lbs of torque. Has anyone dynoed this mod. I understand removing the pup cats will give you more hp. Also will the car smell without the pup cats installed, I know the zo6 doesnt have them at all.
Old May 6, 2002 | 10:56 PM
Face's Avatar
Face
Default Re: Off Road X-pipe (golfman)
What brand are you looking at?
Old May 6, 2002 | 11:00 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Take a look at my post here. http://forums.corvetteforum.com/zerothread?id=288577
:cheers:
-Tuan
Old May 6, 2002 | 11:08 PM
2001C5's Avatar
2001C5
Cruise-In II Veteran
I have the bassani off road pipe that has 2 x's. It do not think it I picked up the numbers you quoted, but I have nothing to back that up. However, I did run my best et and mph after installing the pipe.
As to the smell, it is noticable be not over bearing with my Bassani cat back. For some reason there is no smell at all with my PRT's at the end of the off road pipe.
The sound is awsome.
Here is a link to my bassani with the off road pipe.
http://2001c5.com/images/mov00002.mpg
[Modified by 2001C5, 9:10 PM 5/6/2002]
Old May 7, 2002 | 01:05 AM
borba's Avatar
borba
Default Re: Off Road X-pipe (2001C5)
Can you still pass smog with no cats? :smash:
Old May 7, 2002 | 01:11 AM
Former Vendor
Default Re: Off Road X-pipe (borba)
You're guaranteed to fail without the cats. :yesnod: :yesnod: :yesnod:
Old May 7, 2002 | 01:14 AM
borba's Avatar
borba
Default Re: Off Road X-pipe (Tuan Le)
That's what I thought but I guess some people know the way around that issue! :nono: :flag
Old May 7, 2002 | 01:25 AM
2001C5's Avatar
2001C5
Know don't have to know a way around it if your city does not require an inspection.
Old May 7, 2002 | 01:30 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
I'll have an off road X-Pipe shortly with flages so you can bolt the cats in and out. Should be around $125 with flanges for the cats and X-Pipe.
Old May 7, 2002 | 09:40 AM
ncvetteman's Avatar
ncvetteman
If you just use the X-pipe in its most common application, to replace the factory H-pipe. You can probably expect 1-5hp on a close to stock car based on what members have posted in the past.
To Off Road X-pipe
