Hood light doesnt work/engine compartment
Old Nov 14, 2011 | 12:29 PM
1powdercoater's Avatar
1powdercoater
Default Hood light doesnt work/engine compartment
I changed the bulb even though the existing one looked good, still doesnt work. Is this thing one of those mercury switches?
Old Nov 14, 2011 | 12:41 PM
lucky131969's Avatar
lucky131969
Is it plugged in?
Old Nov 14, 2011 | 12:57 PM
1powdercoater
Default plugged in
I'm assuming it is. I just got it and I don't see where it might be disconnected, at least I don't see it. The guy did have one of those XM radio things in the dash cubby hole that hooked up to something haven't had a chance to look yet. Only mentioning it thinking he might have used the hot wire from the hood for it. Don't know.
Old Nov 14, 2011 | 01:00 PM
lucky131969
I doubt that someone would wire the XM radio into the hood light
Follow the harness from the bottom of the light down the hood. Eventually you will find a connector......very common to find them unplugged.
Old Nov 14, 2011 | 01:05 PM
1powdercoater
Default ok
Ok, I'll check it out when I get home tonight. Thanks for the tip.
Old Nov 14, 2011 | 02:09 PM
z06c5209's Avatar
z06c5209
Check fuse # 2 inside passenger side fuse box. I had the same problem and it was caused by a blown fuse.
Old Nov 14, 2011 | 02:12 PM
1powdercoater
Default fuse
Thanks, I'll ck that out also.
Old Nov 14, 2011 | 04:01 PM
dougbfresh's Avatar
dougbfresh
The hood light connects to a connector right behind the radiator-some people disconnect for ???? reason. Just follow the wires DOWN.
Old Nov 15, 2011 | 08:23 AM
1powdercoater
Default light
Ok, It was disconnected down by the radiator and works now.
That guys I appreciate the help. Sometimes I forget to consider the obvious lol
Old Nov 15, 2011 | 12:11 PM
hotwheels57's Avatar
hotwheels57
It should automatically go out after approx. 15 minutes with the hood open. You might verify that. If it doesn't maybe that's why the original owner disconnected it.
To Hood light doesnt work/engine compartment
