fast 102 on ls1 ?
Old Nov 14, 2011 | 11:07 PM
wes427's Avatar
wes427
Default fast 102 on ls1 ?
i have a fast 102 intake but the stock size injectors are to small for the hole in the fast intake. im guessing its for a ls3 style injector are there adaptor sleeves, im buying injectors anyways just need to know what to look for i also have billet rails that fit the ls1 stock injectors
Old Nov 14, 2011 | 11:17 PM
wes427's Avatar
wes427
are the ls2 style injectors larger in the bottom oring than the top?
Old Nov 15, 2011 | 12:41 AM
silver408z's Avatar
silver408z
I cant say about the injectors or not but you could be right about it being for a ls3. The real problem isnt the injectors because those are easily changed the problem is the intake port design. Ls1's have a cathedral port and the l92/ls3/ls7 have rectangular ports. The rectangle ports will not work on a cathedral port and vice versa. They do make a 102 for cathedral ports. Check your part numbers on a fast's web page or something similar.
To fast 102 on ls1 ?
