View Poll Results: Where did you place your wideband sensor
Passenger side near collector
5
18.52%
X-Pipe
7
25.93%
Rear O2 sensor bung w/ no cats
5
18.52%
Other
10
37.04%
Voters: 27. You may not vote on this poll
Wideband Sensor Placement
Old Nov 16, 2011 | 07:30 PM
Chrisrokc's Avatar
Chrisrokc
Default Wideband Sensor Placement
I wanted to put up a poll to see where everyone is putting their wideband sensor.
I just purchase a LC-1 and I am unsure where I should place it in the exhaust system. I have read all the threads. So vote and post! Thanks
I guess it is important to note that my xpipe is about mid car.
Old Nov 16, 2011 | 07:46 PM
tlove32's Avatar
tlove32
If you have long tubes and no cats, use the rear 02 sensor bung
Old Nov 16, 2011 | 08:03 PM
SargeZ06's Avatar
SargeZ06
Driver side near the collector and in front of the CATS if you have them.
Old Nov 16, 2011 | 08:19 PM
Chrisrokc's Avatar
Chrisrokc
I am cat less and this is a s/c car.
Old Nov 17, 2011 | 12:46 AM
StingrayRebel's Avatar
StingrayRebel
+1... i had lg weld a wideband bung in my longtubes and i was told the most accurate place is in the driver side collector... they welded it on the opposite side that the o2 bung was located
Old Nov 17, 2011 | 01:08 AM
FourG63 97GST's Avatar
FourG63 97GST
+2
theoretically #7 is the leanest cylinder, hence why you want to monitor that bank.
Old Nov 17, 2011 | 10:00 AM
95BlueBomber's Avatar
95BlueBomber
Got mine installed right in the middle of the X-Pipe
Old Nov 18, 2011 | 08:40 AM
chevylad's Avatar
chevylad
I have mine on the drivers side before the cat. I think I did it there just because that is where I had the most room. Keep in mind the sensor needs to be between 3 and 9 o'clock up high, but I'm not positive why. I think it was to keep moisture off the sensor. It was something I read somewhere a long time ago.
Old Nov 18, 2011 | 06:11 PM
LoneStarFRC's Avatar
LoneStarFRC
That's where I have mine as well.
Old Nov 25, 2012 | 12:20 AM
zwaldo's Avatar
zwaldo
I've heard the same thing, don't want moisture to condense on the sensor and sit on it and ruin it...
Old Nov 25, 2012 | 01:10 AM
RonSSNova's Avatar
RonSSNova
The XS power have a bung in the X-pipe and I used it.
Ron
Old Nov 25, 2012 | 08:53 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
That is where ECS installed mine.
I Keep in mind the sensor needs to be between 3 and 9 o'clock up high, but I'm not positive why. I think it was to keep moisture off the sensor.
To Wideband Sensor Placement
