Tires Tires Tires
Old May 7, 2002 | 12:53 AM
TDogg72's Avatar
TDogg72
Default Tires Tires Tires
I just bought a 99 Hardtop Vette today.
The tread on the tires is very low and they will need to be replaced soon.
I am just wandering what a good set of tires is for C5's that last a good while(if you arent driving real hard), and arent too expensive.
What are some options?
Thanks.
Old May 7, 2002 | 01:26 AM
Bill Reid's Avatar
Bill Reid
Default Re: Tires Tires Tires (TDogg72)
...and arent too expensive. What are some options?
Hmm... I think we still have a set of near new Goodyear take off's if you are interested. Give us a call :)
Old May 7, 2002 | 09:40 AM
TomLzzz's Avatar
0TomLzzz
Former Vendor
Default Re: Tires Tires Tires (billreid1@***.net)
Check out the Eagle F1 GS at Tirerack. The rear 275/40/18's are $166 each. The fronts are 120 something. These are the non-runflats. I bought a set for a little over 600 deliverred and had them mounted at Discount Tire.
Old May 7, 2002 | 09:58 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Tires Tires Tires (TomLzzz)
If your looking for a cheap tire and your willing to go with a non-runflat, check out the Nitto tires. They offer good performance for the price.
Old May 7, 2002 | 10:07 AM
Lil Red's Avatar
Lil Red
Good post, i'm looking for input as well. I only need rear tires! Guess i've got to loose a lil weight in that right foot :yesnod:
Old May 7, 2002 | 03:10 PM
jdavis's Avatar
jdavis
Short of a good set of Goodyear EMT "take offs", the best dollar value is going to be Firestone RFTs or Yokohama run flats. The Firestones have a higher tread wear rating than either of the others and rides and performs better than most.
Old May 7, 2002 | 03:39 PM
ShanMan14's Avatar
ShanMan14
Cruise-In II Veteran
Cruise-In V Veteran
Default Re: Tires Tires Tires (jdavis)
Least expensive tires that I've been happy with are the Sumitomo HTR-ZII's. Good tread wear, quiet and inexpensive. You won't see a lot of mention of that tire here, but I can vouch for it.
$184 at Tirerack.com for a 285 35/18. Fronts are cheaper of course.
Old May 7, 2002 | 04:43 PM
SEAMOORE's Avatar
SEAMOORE
I also have a 99 FRC. Got rid of the runflats at about 26,000 miles. Went w/ Nitto 555's (stock size) and love them. Smooth, good grip, quite, and look good. Wear looks good also. Out the door for approx. $800 including the high grade balancing job. New tires, frc partition (which i made) and the $19.95 stero upgrade and it's like having a new car.
Old May 7, 2002 | 05:07 PM
TDogg72's Avatar
TDogg72
What is the advantage of having the RunFlats? Besides the obvious(run when its flat).
Old May 7, 2002 | 05:18 PM
lostsoulny's Avatar
lostsoulny
Bill can you email me a price on take off rears it is almost that time :seeya
thanks
George
Old May 8, 2002 | 09:48 AM
nevadacoin's Avatar
nevadacoin
Default Re: Tires Tires Tires (lostsoulny)
personally I would not cut corners on the tires..expense is just part of ownership.... :yesnod: :yesnod: :seeya
Old May 8, 2002 | 10:04 AM
ncvetteman's Avatar
ncvetteman
Thats the only advantage. They are very heavy, ride bad, and perform bad.
Old May 8, 2002 | 05:03 PM
Futch's Avatar
Futch
Default Re: Tires Tires Tires (ncvetteman)
If you have a blow out with either tire, you're stuck. The only consideration is for a repairable tire.
Run flats are useless, basically. With an air pump/ repair kit in the car, you can regulate a small leak in a non-run flat tire until you can limp into a tire shop for repair or replacement, necessary for either type. The runflat just means you don't have to stop for 50 miles or so to do the same thing, repair or replace, for a higher price. And they are a be-Ach to get on & off since the bead is so thick. You'd prolly have a difficult time finding anyone in BFE to handle the repair, much less the replacement of a run flat. If it were my daughter or wife alone on the highway at night, sure, for emergencies like escaping rapist serial killers. But me, not even a consideration. They are a waste of money & a performance pooper.
To Tires Tires Tires
