Aftermarket Master & Slave
Old Nov 18, 2011 | 10:48 AM
fendermender's Avatar
fendermender
Default Aftermarket Master & Slave
I did several searches but came up empty. Anyone used them? In particular the Dorman ones. I have to pull the engine and figure to replace the 12yo hydraulics as a "may as well". At 70thou I'm hoping the actual clutch is still good.
Old Nov 18, 2011 | 02:32 PM
tlove32's Avatar
tlove32
GM slave is fine. Get a Tick master if you need the adjustabilty, otherwise the GM master is fine too
