Diff Fluid-Metal?
Old Nov 19, 2011 | 10:32 PM
Endeka's Avatar
Endeka
Default Diff Fluid-Metal?
I drained my diff and refilled it. I extracted some fluid from the stream into a test tube and tried to do a magnetic separation, but afterwards I had to conclude that the metal was non-ferric because it didn't separate. Then, I put it upright for about six hours and saw what shook out. There is an impossibly small amount of metal in there-perhaps 6-8 pieces which are smaller than normal-sized sand grains (about 1/5 the size of a flake of glitter) and can only be seen when they shine in the light. Otherwise, the fluid has a high opacity; even placing it in front of a light does not illuminate it-it is that dark. Is that normal, or should it have had absolutely no metal at all? I haven't gotten to take the car on the highway yet, so we'll see if this had any effect.
Old Nov 19, 2011 | 11:29 PM
Dale002's Avatar
Dale002
It's going to make some metal dust as I've heard other call it. I think you'll be alright.
Old Nov 19, 2011 | 11:40 PM
C5FORFUN2's Avatar
C5FORFUN2
Sounds like a small amount of normal wear. Not knowing how many miles since it was changed, that would be excellent if it had not been changed since the normal 60,000 service interval.
Old Nov 20, 2011 | 03:14 AM
Endeka's Avatar
Endeka
The car just changed hands around 58,000 miles, and it now has 82,000, so my guess is that this service might have fallen through the cracks; it wasn't with the other records this owner provided.
Old Nov 20, 2011 | 07:35 AM
spdislife's Avatar
spdislife
I wouldn't worry.
Old Nov 20, 2011 | 06:24 PM
Dope's Avatar
Dope
Resident moron
The opaque, sparkly non-ferrous material is probably the wear material from the limited slip clutches. As long as there isn't too much you should be fine. When I blew my rear, the entirety of the fluid was sparkly dark gray colored and had dozens or hundreds of little chunks of clutch material in it.
Dope
To Diff Fluid-Metal?
