O2 Sensor Harness
Old Nov 25, 2011 | 05:37 AM
J_B's Avatar
J_B
Default O2 Sensor Harness
Before I left for this deployment, I installed a set of TSP longtube headers. My plan had been to run the front O2's and get the rear ones tuned out. I ran without O2's plugged in for a few weeks and about two weeks before I left I went to get the O2's back in and tuned. However, I apparently had not secured the harnesses good enough and the front driver side harness connector melted to my headers.
I thought I'd be fine just running the rear O2 to the front connection but when I went to do it, I noticed that the connections are different for the front and rear O2's, the fronts have a male connection coming off the car and the rears have a female. What I'm wondering is if the front and rear O2's themselves are different, because if not I can just cut off the connection for the rear O2 and splice it onto the front. If not, then I guess I need to find a new wiring harness somewhere.
I tried searching and couldn't find any information, thanks for any help.
Old Nov 25, 2011 | 06:02 AM
Vicarious.'s Avatar
Vicarious.
Don't drive your car without front O2 sensors IMO.
Just buy a new male and female connector and solder them in. Then use a large heat shielding sheath to slip over the connection.
There is a seller on ebay that sells the pigtails for only around $10 each. I just went through with this last week.
its a ***** to solder the male side from above the headers, but its not impossible.
http://www.ebay.com/itm/260251244852...84.m1439.l2649
http://www.ebay.com/itm/LT1-LS1-Oxyg...item5883c16237
Old Nov 25, 2011 | 09:27 AM
lucky131969's Avatar
lucky131969
In my opinion, hacking up the wiring (when the correct adapters are available) is just hillbilly! LG has the correct adapters, to facilitate the use of the rear O2 sensors, in the front positions.
Old Nov 25, 2011 | 01:46 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree - the wires and specifically the wire cover or jacket has a special coating to keep them working in a High heat environment---I have seen maby 02's "home wired" before and even by electricians---Most ALL eventually FAIL--
I would get the adapter pigtails from the vendor mentioned or try "Casper's Electronics"
As far as the rear 02's themselves many people use them on the fronts when installing LT's----They heat up quicker and are are sensitive--When using LT's the front 02 bungs can be as far rearward as 3'----so you get erroneous 02 readings or sometimes they won't work at all---
Old Nov 25, 2011 | 11:08 PM
rws.1's Avatar
rws.1
My headers melted the wiring on my front my O2's as well.
Unfortunately I was away on business and my wife had to deal with it.
A local garage ( not a dealer) ordered a replacement set of 02 pigtails
and solved the problem.
Old Nov 25, 2011 | 11:39 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
what's wrong with soldering wires together?
Old Nov 26, 2011 | 12:48 AM
Vicarious.'s Avatar
Vicarious.
What I did was...I ordered the pig tails from ebay (had never heard about the other pigtails from LG until lucky mentioned it in this thread), I used 2 layers of rubber heat shrink on all 4 individual wires after they were soldered. Then I wrapped the whole bundle with about 15 inches of this aluminum heat sleeve. Then I wrapped a couple layers extra protection on the header side of the heat sleeve with this heat tape. My wire bundle still does not touch my headers with all of this heat shielding (and I am running Kooks 1 7/8")
My total cost was about $50...but I don't think there is ANY chance my wiring harness will ever melt again after being wrapped in heat shrink & 1/4 inch thick layer of aluminum coated fiberglass.
Old Nov 26, 2011 | 06:18 AM
J_B's Avatar
J_B
Thanks for all the replies, guess I'll order a new pigtail for when I get home.
Here's a pic of my melted one
Old Nov 27, 2011 | 01:27 PM
tblu92's Avatar
tblu92
Solder can melt--with extreme heat-even if the joints do not come apart completely they loose conductivity at the joint(voltage)
Old Nov 27, 2011 | 01:46 PM
lucky131969
I agree......if .....you use the wrong type of solder. Using a high temp alloy will ensure this isn't an issue. That being said, the issue with solder melting is not the primary concern with a soldered connection, as it pertains to an automotive application, particularly in an environment of heat cycles and vibration.
Once two wires are soldered together, the mechanical bond becomes the strongest point in the wire. It also makes the copper strands, at the end of the solder point, more rigid/brittle. Without the correct strain relief, that now becomes the weak point at the connection, and the wire will break at the solder joint. In a wire bundle that is straight, not subject to bending/flexing, and where the wires are properly secured on either side of solder type repair.......it's not an issue.
To O2 Sensor Harness
