Bad weld on the suspension bracket
Old May 7, 2002 | 06:23 PM
C5 Frederik's Avatar
C5 Frederik
Default Bad weld on the suspension bracket
During changing my tires I took the chance to take a picture of my suspension bracket on the rear axle. In the picture you can see the upper front bracket on the left. Still remember our forum member BatMobile with that broken bracket.
Well, as you can see, mine is crap too. The upper part must have been welded by robot, it looks very good, but the lower one is a manual weld, done very bad. I will show this pic to my local dealer. I am interested how he reacts.
As I did not have time enough I did not inspect the other weldings. Will do it later!
Frederik
[Modified by C5 Frederik, 12:36 AM 5/8/2002]
Old May 7, 2002 | 06:45 PM
99 Corvette's Avatar
99 Corvette
Default Re: Bad weld on the suspension bracket (C5 Frederik)
If he is anything like the dealers on this side of the Atlantic he will probably say "it is normal" :rolleyes: :mad
Jerry
Old May 7, 2002 | 06:53 PM
ghost.rider's Avatar
ghost.rider
Uh - oh :eek:
This is two.
And both are out of the country. I don't know if your's is the same year as Batmobiles(?). If they are the same it would be interesting how close the Vin's are.
Hopefully this second one will get GM's attention a little more than the first one. :smash:
Old May 7, 2002 | 08:13 PM
B. Stewart's Avatar
B. Stewart
Did you buy your car new?
Old May 7, 2002 | 11:48 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Bad weld on the suspension bracket (B. Stewart)
I am almost afraid to look at mine now! :nonod:
Old May 8, 2002 | 12:26 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Bad weld on the suspension bracket (C5-VERT)
Make that 3 my buddy 2000 vert just had the same problem. This is total
:bs
Old May 8, 2002 | 09:40 AM
jdavis's Avatar
jdavis
Default Re: Bad weld on the suspension bracket (Snake Slayer)
Does anyone know what is happening with Batmobile's car?
Old May 8, 2002 | 09:49 AM
2manycars's Avatar
2manycars
From: I know when the doggie he piss onna ma leg...
St. Jude Donor '14
Default Re: Bad weld on the suspension bracket (jdavis)
He hasn't posted about it in awhile. I'm pretty sure he had the lawyers going at it, though. Probably why he's been quiet about it lately.
BTW, my welds appear to be alright.
[Modified by 2manycars, 8:49 AM 5/8/2002]
Old May 8, 2002 | 06:34 PM
C5 Frederik
No, 1 year old with only 4kmiles. It had one preowner who stored the car in winter for 4 month. I got it in a perfect condition. I know why you are asking. But as far as i inspected the car it didn´t have any crash or damage.
What you see is what you get from factory. And I am not willing to accept this :smash:
Frederik
Old May 8, 2002 | 07:43 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
I'm going to take a look at mine and see. :reddevil
-Tuan
Old May 9, 2002 | 09:11 AM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
Default Re: Bad weld on the suspension bracket (Buckmaster)
I have been remiss with keeping you all updated...
Here is an update I JUST posted.
http://forums.corvetteforum.com/zerothread?id=296737
I am hoping that GM is paying good attention to this. Someone is gonna get themselves killed out there!!
FWIW...before you all claim it is an export thing...my car was purchased and titled in the US as a US Spec vehicle. Not that it makes any difference, all the frames roll down the same line and are identical.
Gonna cost GM some BIG bucks in the end to fix this, as I sense it is probably several hundred cars. The bracket/frame need to be ground back down and rewelded. The problem being that the bracket cannot come off of the car. It actually also welds on the bottom and top sides of the frame. The top side weld would be impossible to get to without taking the body off of the car.
:eek:
Neill
Old May 9, 2002 | 01:31 PM
lotzahp's Avatar
lotzahp
This is an alarming trend too dangerous to ignore. How/what/where do I check my car for this?
Old May 9, 2002 | 02:02 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
Default Re: Bad weld on the suspension bracket (lotzahp)
http://forums.corvetteforum.com/zerothread?id=262516
To Bad weld on the suspension bracket
