Vararam installed, now issues
Old Nov 28, 2011 | 09:10 PM
M56x-11's Avatar
M56x-11
Originally Posted by rebelheart
LOL I will be 61 in January!
Well I'll be 48 in March... My hats off to you SIR!!
Old Dec 18, 2011 | 10:31 PM
magracy's Avatar
magracy
make sure the maf is not pushed into the air horn to far, can cause terbulence. check instructions for proper install.
Old Dec 18, 2011 | 10:39 PM
M56x-11's Avatar
M56x-11
Ive chcked all of whats been mentioned. So now the car just_st sits in the drive and looks good. But I want to drive it's anyone got any ideas of.these issues.
Old Dec 19, 2011 | 06:59 PM
Garys08Z06's Avatar
Garys08Z06
St. Jude Donor '12, '15
I installed the Halltech 1/8" air straightner when I installed my Vararam. It's suppose to help the Vararam from surging.....when I started mine up there were no problems. Also, I am 65 years old.
Old Dec 19, 2011 | 07:30 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Don't take this wrong, but if you had installed everything correctly you should not be having this many problems. I am not a fan of the VR Power Duct but even with it the car should at least run. You have missed something, an air leak from a loose connection, didn't plug the MAF sensor wire back in, vaccum hose off, too much oil on the K&N filter and your MAF wires are fouled really bad,,,,something!
Take your time and check every phase of the install and get back to us so we can help. If the car won't run it should be/have throwing/thrown codes.
Old Dec 20, 2011 | 12:57 PM
cdkcorvette7's Avatar
cdkcorvette7
OH, I've put on around 30 or so.. maybe not even that much..
Drive it some more. If you get over 100 miles with the Vararam and still have these issues come back... If you're sure you have an issue get under there with some carb cleaner and look for vacuum leaks.
Just out of curiosity, did your MAF have a screen on it?
Old Dec 20, 2011 | 02:01 PM
M56x-11's Avatar
M56x-11
I replaced the MAF, I went over everything with a fine tooth comb. And its never thrown a code. But I still get the transmission studder at lower RPMs .oh I've put over 1k on it.
I am at a total loss. And I greatly appreciate the help guys.
Old Dec 20, 2011 | 02:18 PM
cdkcorvette7
Don't throw parts at it; that'll get very expensive. When you say it's never thrown a code do you mean you've never seen a warning message come up or do you mean that you're actually pulling your codes from the DIC and seeing nothing. If the surging is strong enough that your car dies at traffic lights you definitely have problem somewhere. Did this start IMMEDIATELY after the vararam install?
Check the PCV elbow off the front passenger side of the intake manifold. They rot and break pretty often.
Old Dec 20, 2011 | 02:39 PM
M56x-11's Avatar
M56x-11
Never gotten a code off the DIC and taken it to the dealer..again nothing. I replaced the MAF due to the screen had huge holes in it, as if a screw driver had been jammed though it at some point.
I'll check the PVC elbow when I get home tonight. Thanks for the suggestion.
Old Dec 21, 2011 | 06:42 PM
M56x-11's Avatar
M56x-11
Well I checked, double checked. Found no holes, leaks or loose fittings. So I installed a Granatelli MAF with cold air tuning I purchased off a forum member. It runs much better, but it stills has a small, very slight issue at 1000rpms. I didn't drive it much tonight, I'll drive it to work and see what happens.
I'm taking the OEM MAF with me, Just in case!!
Again, thanks for all the help guys. Greatly appreciate it.
Old Dec 25, 2011 | 05:15 PM
M56x-11's Avatar
M56x-11
Well that didn't work. I'm lost lost lost. Time for a tune!!
Old Jan 1, 2012 | 01:43 PM
M56x-11's Avatar
M56x-11
THE ISSUE IS RESOLVED!!!
Found the culprit to my issue. I was using the stock power duct or bridge intake piece. You know what I'm talking of... where the powerduct and the accordion pieces attach to each other. Well that fitting was so loose, it was sucking in unmetered air. So, I first taped it up,, that did work. but only for a short period of time.
So I ordered a Vararam PD installed it.. and wola.. NO ISSUES!!
I'm stocked!!
Thanks for all the suggestions everyone, greatly appreciate it.
Old Mar 5, 2012 | 07:48 PM
  #33
WICKEDFRC's Avatar
WICKEDFRC
I'm stocked!!
I just now found this thread and posted elesewhere on another forum and asked the EXACT SAME QUESTION because like you, I was experiencing the EXACT SAME ISSUE!!
I have a 2000 FRC and although it idles smoothly at 750 RPMS, I think it needs to be upper towards 1000 like yours. Like you, I have the normal daily driving "Come to a stop light" dip in RPMs that go so low, the car may stall. How many times have you found yourself revving up the car as you slow down for a light, just to keep it from stalling?
Mine seemed to get worse with hot weather.
Ok, so now that you nailed this culprit, please tell me the part number you urchased from VR? I too have the stock air bridge.
Thanks, and glad you figured it out!!!! Its been annoying me too!!!!
What are your RPMs set at? 1000? Mine were at 1000 but lowered to 750, so I think that has something to do with it as well.
PS: I will be 44 in March too.
